SolaraGuy.com • View topic - Idling speed
Idling speed
Idling speed
Postby makethemusic72 » Thu Apr 23, 2009 1:25 pm
Hey guys, what is a healthy idling speed for a 2003 4 cylinder automatic solara?
its idling in drive at about 5-600 and the same when it's parked.
I did a battery disconnect about 2 weeks ago, After i did that, my idling speed was F@#$%^&. I talked to some guys and they were like "your ECU is reset, and if you give it some time, It will re-learn your car"
I cleaned the throttle body twice in two days, about two days ago. the first time i cleaned it, It solved the idling problem. it was idling parked at 1100, and in drive at 900. When i cleaned it again the next day, The idles were again messed up, now it's idling like it used to. What in the world did I do?
Thanks all!
Tyler
2003 Solara 4 Cyl, automatic. Floss as @#$%.
makethemusic72
Postby makethemusic72 » Wed Jun 24, 2009 8:46 am
sorry, it's been awhile.
coud it be my MAF sensor? if i cleaned that would it make a difference?
or should i take it to a Toyota tech and get them to reset my ECU?
makethemusic72
Postby ToyoSolV6 » Wed Jun 24, 2009 9:00 am
hey man i have the same problem after my battery was disconnected, the rpm's are still retarded and hasnt gone back to normal.
Postby D-money » Wed Jun 24, 2009 11:50 am
you can reset the ecu your self just disconnect the battery for a couple minutes
D-money
Postby makethemusic72 » Wed Jun 24, 2009 4:36 pm
D,
would that fix my problem though? like bring it back to 1100/900 rpm? its still idling low. Keep in mind my problem is from a battery disconnect
makethemusic72
Postby D-money » Wed Jun 24, 2009 4:53 pm
after i cleaned my throttle body my car now idels aroung 780 rpm but mine is a v6 do you have any chugging at idle speed? does your tack needle bounce?
D-money
Postby makethemusic72 » Wed Jun 24, 2009 11:46 pm
^ yeah man. very slightly, but it is definitely doing it, why?
makethemusic72
Postby D-money » Thu Jun 25, 2009 1:00 am
it sounds like your ecu reset when the cleaner was still in your engine try to do the reset again disconnect the positive terminal for about five minutes and turn your lights on to drain any stored power.reconnect it start the car let it idle for a 3or4 minutes on its own then do a few quick punches that rev up to 5500 id say about 10 times that should give your ecu the readings it needs to set everything. let me know how this goes if this doesnt solve your problem you may need to do a more detailed cleaning
D-money
Postby makethemusic72 » Sat Jun 27, 2009 5:17 am
thanks. I will definitely try this today. I'll let you know.
makethemusic72
Postby makethemusic72 » Sun Jun 28, 2009 10:46 am
Alright, so i did it, but my idling speed is still ~600. will the car re-learn the idling speed?
makethemusic72
Postby D-money » Sun Jun 28, 2009 10:54 am
the car will take about a halfr hour of driving to fully reset
when it is idling does it feel like it it struggling to stay running or does it feel consistent?
D-money
Postby makethemusic72 » Sun Jun 28, 2009 4:53 pm
it feels consistant, thankfully.
makethemusic72
Postby D-money » Sun Jun 28, 2009 6:12 pm
well it sounds like it is running the way it is supposed to your tach might be off a little but i dont think the rpm is anything to worry about now let us know if anything pops up
D-money
Postby solara90 » Sun Jun 28, 2009 9:29 pm
my idle is always inconsistent o my lara..
02 solara 2az
solara90
Postby toytim » Mon Jun 29, 2009 9:54 am
We have the same problem, when the engine warms up and are sitting at a light in drive the engine idles down and the whole car shakes a bit. It actually stalled at the light a couple times. I cleaned the intake, put new plugs/wires and filter too. I reset the ECU a couple times since but no change. I'm thinking a sensor. Any help would be great, Tim
Happiness is a pair of Solara's!
toytim
