SolaraGuy.com • View topic - Alarm Issue
Alarm Issue
Alarm Issue
Postby SpeedySolara » Fri Apr 24, 2009 2:44 am
I lost the keys of my car so I got a key cut at Toyota to at least get in the car and get my stuff. I want to disconnect my alarm so that I can drive it to an alarm shop and get a new one put in. How do I disconnect or deactivate my alarm? By the way, the key isnt programmed yet.
SpeedySolara
Postby Mole » Fri Apr 24, 2009 9:57 am
if you get passed the point of disabling the alarm, the car won't start since your new key is not programmed.
there should be a toggle by the kick panel to the left of the brake pedal.
Postby TLMNICK » Fri Apr 24, 2009 10:51 am
You can disconnect the battery.....put the key into the ignition and turn it to the "on" position. Reconnect the battery with it like that.
That stops a lot of alarms from singing. Failing that, you'll have to either cut the siren under the hood, or go under the dash, and find + disconnect the brain.
TLMNICK
Postby SpeedySolara » Fri Apr 24, 2009 11:36 am
TLMNICK wrote:You can disconnect the battery.....put the key into the ignition and turn it to the "on" position. Reconnect the battery with it like that.
Very, very interesting. I will try to do that but as far as finding the brain, I hope I'm lucky but to me its simply wires. Does anyone have pictures?
SpeedySolara
Postby SpeedySolara » Sat Apr 25, 2009 7:39 pm
I didnt find the toggle button, which is really weird because they usually have them. At any rate, I managed to disable the alarm but the car wont turn on. It cranks but doesnt start. Toyota was telling me I needed a whole new computer and 3 keys to get programmed for a total of about 1$1200-$1500, its absolutely insane. Any solutions?
SpeedySolara
Postby TLMNICK » Sat Apr 25, 2009 8:09 pm
they're just shooting you BS. I highly doubt you need a new computer.
All you need to do is program that key you got. I could swear there was a tutorial for that...but maybe I'm thinking another car.
TLMNICK
