SolaraGuy.com • View topic - bigest tire fitment
bigest tire fitment
bigest tire fitment
Postby D-money » Fri May 01, 2009 6:17 pm
so i was wondering what the biggest tire size that will fit on my stock 16s im looking for width and heigth
D-money
Re: bigest tire fitment
Postby RandySolara » Fri May 01, 2009 6:23 pm
D-money wrote:so i was wondering what the biggest tire size that will fit on my stock 16s im looking for width and heigth
Ive tried P245/40/18 it fit but its very close
RandySolara
BAN sticked
Postby kingkakyle » Fri May 01, 2009 6:48 pm
urs r 18s he's looking for 16s lol
Postby RandySolara » Fri May 01, 2009 7:52 pm
ahahahah sometime i have problem with reading and writing ;) i admit it honestly heeheh
anyways i think 65 is maximum for rim stock 16s it will be..
P205/65/16 or you can go for P215/65/16 i had it on my Solara 99 my Solara 2001 is P205.
RandySolara
BAN sticked
Postby DaTwUnKrAziEpInOy » Fri May 01, 2009 9:13 pm
215/50/16
DaTwUnKrAziEpInOy
Postby corlon » Fri May 01, 2009 9:47 pm
i used 235 45 series winter tires. they bulged a little bit, but no rubbing or uneven wear.
NiCe
corlon
Postby RandySolara » Sat May 02, 2009 5:05 pm
corlon wrote:i used 235 45 series winter tires. they bulged a little bit, but no rubbing or uneven wear.
Whats ur Rim's size bro ? ive tried 245/40/18 its too close, the guy says when i run over a bum it will touch.
You're probably using rim 17 ? or 16 ? dont know if P235/45/18 fit on Solara 2001 sle v6
RandySolara
BAN sticked
Postby Mole » Sat May 02, 2009 6:03 pm
Postby corlon » Sun May 03, 2009 9:37 pm
he said for 16". so 16".
NiCe
corlon
Postby D-money » Sun May 03, 2009 11:12 pm
will a 225/65/16 fit on the stock 16 alloys for gen 1 with no issues?
D-money
Postby RandySolara » Mon May 04, 2009 5:58 pm
D-money wrote:will a 225/65/16 fit on the stock 16 alloys for gen 1 with no issues?
It will fit bro, P225 is the max size recommended for Solara 99-01 and rim 16 is just small so it will Fit.
Ill probably try P235/45/18 or P225/45/18 i dont know which one is best and comfort. Ive seen those pro in other topic, most of them uses P225/40/18 though.
RandySolara
BAN sticked
Postby TMMK Toy » Tue May 05, 2009 9:33 am
If you want to stay as close to stock circumference as possible, go with a 225/55R16. On a side note, I noticed that a 235/45R17 is close to stock circumference as possible for a 17'' wheel. Would that fit on a 4th gen camry running a 17x7.5 wheel with +35 offset?
TMMK Toy
Postby RandySolara » Tue May 05, 2009 3:39 pm
TMMK Toy wrote:If you want to stay as close to stock circumference as possible, go with a 225/55R16. On a side note, I noticed that a 235/45R17 is close to stock circumference as possible for a 17'' wheel. Would that fit on a 4th gen camry running a 17x7.5 wheel with +35 offset?
This mean P225/45/18 is perpect for Solara 2001 ?
RandySolara
BAN sticked
Postby TMMK Toy » Wed May 06, 2009 8:15 am
looks like 225/40R18 is closer in circumference and 235/40R18 is even closer
TMMK Toy
Postby JvR » Wed May 06, 2009 8:56 am
I use for my gen 4 Camry (i think it is the same) 225/40R18
I think 45R18 would also be okay.
When i have to buy new rims i would go for 17 inch, because every big bump in the road could kill the rim.
JvR
