SolaraGuy.com • View topic - Tire question
Tire question
Tire question
Postby onefiend » Sat Jul 12, 2003 4:47 pm
I asked this in the aftermarket forum, might as well ask it here too..
will 235/40/18 fit on Solara's or will it rub?
anyone here at Solaraguy have 235/40/18?
onefiend
Postby Mole » Sat Jul 12, 2003 7:58 pm
im planning to go 235 on my next set.
it looks as if there will be enough room, but then again on the rear i am rolling with spacers. the fronts LOOK like they will clear, but you never know.
Re: Tire question
Postby NASTY » Sat Jul 12, 2003 9:24 pm
onefiend wrote:I asked this in the aftermarket forum, might as well ask it here too..
(but why?)
'01 SLE V6
NASTY
Postby TXSolaraSLE » Mon Jul 14, 2003 10:30 am
I guess it all depends on your rim offset, but i have 18x8" rims with a 40mm offset. I normally run 225/40s but i had a flat and Discount Tire gave me a 235/40 loaner and it its way too wide for the rear fenders. The sidewalls on the 225's will scape the fender a little with 2 guys in the back over medium bumps, but he 235's just bump straight into the inside fender lip, putting gashes in the shoulder of the tire. Even on gentle highway dips yesterday with a trunk full of luggage, i was scraping that one wider tire. I'd stick with 225s.
'99 Black Solara SLE
18" Mille Miglia Evo5
Yokohama AVS ES100
Indiglo Gauges
Kicker KSR100
K&N Filter
Xenon Headlights & License plate bulbs
TXSolaraSLE
Postby WTF?? » Mon Jul 14, 2003 11:55 am
simple solution to this if rubbing happens: cut/roll your fenders at a local shop
think about it... "why adjust the rim/tire size" when you know you WANT it but rather "adjust your car to the rims/tires" you want :lol: :wink:
many ppl on this forum have done this and have said it costs as low as $40
Retired... its been fun Image
WTF??
Postby onefiend » Mon Jul 14, 2003 12:45 pm
I ended up getting the 225/40/18 today... Its what I had on the car previously. I asked the question about the 235/40/18 becuz I bought 2 new tires the other day and wanted 225's but America's Tire Co. accidentally put on the 235's... So I had the 235's for 2 days in the rear, my car felt like it handled better but also felt a lil slower when I was on the freeway and I felt or heard rubbin. Today I went back to buy the other 2 tires and told them about their mistake. They changed the tires back to 225...and I'm happy.
Solara Nytez is right though, why adjust the rims/tires to the car when we can do it vice-versa, but sometimes "change" is difficult. :wink:
onefiend
Postby happy_aggies » Mon Jul 14, 2003 2:31 pm
Getting the right offset at the first time.
That what u should do. :wink:
happy_aggies
Will these work?
Postby DonJuanCU1 » Wed Jul 16, 2003 12:29 pm
I was wondering if these rims would work on my solara since they are 18x8.5". They're ADR Sterlings and I know they'd fit but how well? i need to know the offset too...Thanks!
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=43958
'99 V-6 auto, 19" G-racing Kobe's with Toyo Proxes, injen intake, pioneer head unit, mtx thunder6000 subs, 600W digital Alpine amp, Showoff Xenon Blue headlights and foglights and PIAA blue foglights in air dam. Clear corners and reverse gauges.
DonJuanCU1
Re: Will these work?
Postby happy_aggies » Wed Jul 16, 2003 12:39 pm
It might be but u definetly need to roll ur fender.
DonJuanCU1 wrote:I was wondering if these rims would work on my solara since they are 18x8.5". They're ADR Sterlings and I know they'd fit but how well? i need to know the offset too...Thanks!
happy_aggies
Postby STR8PYP » Wed Jul 16, 2003 12:55 pm
It all depends on the offset.
SC
STR8PYP
Postby TXSolaraSLE » Wed Jul 16, 2003 1:01 pm
i'm not too sure about an 8.5" rim. even with an offset that would keep you from rubbing your fenders, you'd possibly be rubbing your strut. with something that wide, you'd have to make sure it fits as evenly as possible between the strut and fender lip, but even then you'd probably have to roll the fender. stick with an 8" or less and save yourself the grief!
Yokohama AVS ES100
Indiglo Gauges
Kicker KSR100
K&N Filter
TXSolaraSLE
Postby STR8PYP » Wed Jul 16, 2003 1:25 pm
8.5" wide will work, but it will be a VERY tight fit. Offsets are something like +38 and +44, which will prevent you from rotating your tires from front to back. If you go with the same offset all around like I ended up doing, you'll end up having to use spacers and shaving the rear fender.
SC
STR8PYP
Different Rims
Postby DonJuanCU1 » Thu Jul 24, 2003 6:32 pm
i found a good deal for g-racing kobe's 19". i was wondering on the ride quality with toyo proxes fz4 size 225/35/19. i appreciate the help. lookin to purchase tomorrow...if i can get a quick reply.
DonJuanCU1
Postby onefiend » Fri Jul 25, 2003 8:26 am
According to America's Tire Company 19's will fit along with the 225/35/19. There are also a few SG members who Ive seen with 19's on their rides.
onefiend
Postby AzN_DrAgoN48 » Mon Mar 29, 2004 9:41 am
i found rims that are 18x 7.5 with a +42 offset. what size tires should i get?
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
