SolaraGuy.com • View topic - stupid fuggin window motor
Postby xh0rnsb0yx » Fri May 08, 2009 12:30 pm
pulled into my spot tried to roll up the window, halfway up makes this loud ass sound im assuming the motor broke and it would only roll down.
called the stealership and it would be like 500 dollars with labor can anyone tell me how to fix this without having to buy a new motor can i roll it up manually
thanks this fcking car is really starting to piss me off
xh0rnsb0yx
Postby xh0rnsb0yx » Fri May 08, 2009 1:02 pm
well i got the door panel almost off but it wont come off where the door handle is. i got the screw within the actualy door handle (bedind that button) but something else is holding it on there any suggestions?
xh0rnsb0yx
Postby Ilovemylara » Fri May 08, 2009 2:47 pm
Postby lilm » Fri May 08, 2009 4:19 pm
i made a tutorial on the cleaning of the window motor look that up
lilm
Postby bassthrive » Fri May 08, 2009 4:20 pm
thoroughly clean then lube the tracks with lithium grease before you shell out the $100+ bucks for a new motor/regulator assembly
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
