SolaraGuy.com • View topic - Question about Rear/tail running lights !
Postby RandySolara » Sat May 09, 2009 8:09 pm
1, My Solara 2001 Rear/tail running lights arent on even the Lisense Plate light too, they all off, does 2001 model has warning signal when ur lights are dead ? the Brake's lights and Left/Right signalss are ok its just the running lights are dead, but no warning nothing ?
I changed the Park Signal corner light in the front both driver/passenger a week a ago, well i noticed that the Blinking Lights when you Lock/Unlock ur car with the keyless remote control are dead after 1 day i changed, i thought oh its fine who cares about it, i probably driving without Rear Running red light for a week haahahhaah i drive at night time alot, i just found out now like an hour n half ago when my wife wanted to head back home for something or else im outside right now cause its weeken.
Umm weird, i got pulled over for SPORT CHECK twice this week but why didnt Police tells me or give me ticket hmmm. they probably saw my HID is too shiny and beauty so they just let me go hahaaha
RandySolara
BAN sticked
Postby RandySolara » Sat May 09, 2009 9:55 pm
nobody know ? i asks cause i dont know if there something wrong with WIRES, i have no warning lights, if the bulb is no good then i should get the warning light right ? everythin other lights are ok except the TAIL LIGHTS are not ON when i turn it on. Ever happened to any of you ?
If Wires problem i be prepared couple hundreds, i hope not, so i like to get a clue....anyone ?
RandySolara
BAN sticked
Postby Ilovemylara » Sat May 09, 2009 10:02 pm
Its most likely a fuse.I had the same thing happen to me when i was wiring up my led license plate lights, and i accidentally shorted out the wires. all i had to do was change the fuse.
Postby RandySolara » Sun May 10, 2009 7:56 pm
Ilovemylara wrote:Its most likely a fuse.I had the same thing happen to me when i was wiring up my led license plate lights, and i accidentally shorted out the wires. all i had to do was change the fuse.
Yes it was the fuse, thanks bro i just figured out this morning, i called my friend he told me the same, thanks for reply bro.
RandySolara
BAN sticked
