SolaraGuy.com • View topic - seat belt
seat belt
seat belt
Postby D-money » Mon May 11, 2009 8:09 pm
my drivers side seat belt is not retracting like it should any one know how to fix the problem with out replaceing it
D-money
Postby Ilovemylara » Mon May 11, 2009 8:27 pm
Mine does that sometimes, I usually pull it back a few times and it retracts properly. Pull it all the way out and see if its twisted, if not then It might be caused from the sides of the belt getting "fuzzy" from normal wear.
Postby D-money » Mon May 11, 2009 8:33 pm
ive pulled it all the way out nothing twisted nothing fuzzy it retracts most of the way by it self if i lift the buckle to relieve some weight it retracts all the way is there a way to adjust the tensioner
D-money
Postby Ilovemylara » Mon May 11, 2009 8:38 pm
yes, i believe there is a spring adjustment under the tensioner cover.
Postby campfire9 » Mon May 11, 2009 8:57 pm
Go to the sites below for help. Toyodiy.com for parts breakdown and part numbers and the other is gen 2 repair manual which should be about the same for all gens.
Hope this helps
http://www.toyodiy.com/
http://www.solaraguy.com/viewtopic.php?t=35384
Without ammunition, the USAF would be just another very expensive flying club.
campfire9
Postby ralphredimix » Mon May 11, 2009 11:03 pm
Yah there's a tensioner on the main bolt, accessible after you pop open the plastic cover on the seatbelt attachment to the body.
ralphredimix
Postby D-money » Mon May 11, 2009 11:37 pm
is it adjustable
D-money
Postby NeFaRiOuS_SLE » Tue May 12, 2009 10:59 pm
JEEZ, I didn't even KNOW that you CAN adjust the tensioner-- you mean to tell me that instead of leaving my safety belt flopping out on the seat or manually tucking it back in, I could've turned a screw/bolt and have it RETRACT ITSELF :o ?? I thought that the retracting problem was either something that you either had to just deal with or buy replacements! Worst of all, I was convinced that it was because of a soda spill from a long time ago, and thought that it was the stickiness of the sugars binding the mechanism or even the fabric somewhere, but then again I wiped it off immediately and rinsed when I stopped.
THANKS!
