SolaraGuy.com • View topic - Check engine light issues
Postby HydroponiK » Wed May 13, 2009 11:43 am
So I have the following CEL codes, and I know it has something to do with the EGR system based on the codes I got.
So over the weekend, I used throttle body cleaner hoping this would make codes would go away, but unfortunately they are still there. Is there anything else I can do before actually replacing the EGR valve since they are so expensive?
here are my codes:
P0401
P0402
P1411
HydroponiK
Postby HydroponiK » Wed May 13, 2009 5:32 pm
Did some googling, and most point to either the egr sensor and/or the egr vsv that is faulty.
Autozone has the sensor for only $45, and should be an easy DYI. However, I couldn't find the VSV part, and not exactly sure where it is located.
Anyone know how much this part costs, and if it's an easy job?
HydroponiK
Postby Ilovemylara » Wed May 13, 2009 6:07 pm
look on the vacumn line diagram on the underside of your hood... Im pretty sure it lists the vacumn switching valve
Postby HydroponiK » Wed May 13, 2009 8:09 pm
I have a copy of the service manual, and it looks like it's under the black engine cover, however from doing some googling, it's actually under the engine? Can anyone confirm?
HydroponiK
Postby HydroponiK » Sun May 17, 2009 11:39 am
I just replaced the egr sensor, but I lost the socket to remove the nut from the negative terminal lol.
How long should it take for the CEL to go off if I don't reset it manually?
HydroponiK
Postby HydroponiK » Tue May 26, 2009 11:44 am
Just a quick update for you guys.
I replace the EGR position sensor with one I bought from autozone, and after disconnecting the negative terminal, it has been CEL-free for over a week now. Took it to inspection last Friday and passed :)
It's amazing how just one part can cause 3 codes, but I'm happy this is finally resolved.
HydroponiK
