SolaraGuy.com • View topic - question about my car
Postby MiistahSaan » Tue May 19, 2009 1:49 am
i drive a 2000 solara 4 cyl. but ive always wondered. whenever im like a red light or stop sign. and i gas it. the pedal sometimes get stuck. and i have to step harder on it which make the car jump a lil. does anyone know the reason for this?
MiistahSaan
Postby dan99solara » Tue May 19, 2009 5:43 am
try cleaning your throttle body
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby lilm » Tue May 19, 2009 5:56 am
my gas pedal does this too im to lazy to find out why. I would just spray some wd-40 on the linkage on the pedal and see if that helps
lilm
Postby GreenSolara01 » Tue May 19, 2009 8:16 am
you have to push the pedal harder, becuase it is stuck or does it need more gas to move from a stop?
GreenSolara01
Postby D-money » Tue May 19, 2009 9:24 am
it is your TB inside i had the same problem with a corolla i had it is a easy fix
D-money
Re: question about my car
Postby mac-phisto » Tue May 19, 2009 11:38 am
MiistahSaan wrote:i drive a 2000 solara 4 cyl. but ive always wondered. whenever im like a red light or stop sign. and i gas it. the pedal sometimes get stuck. and i have to step harder on it which make the car jump a lil. does anyone know the reason for this?
had a similar problem (though not from start - my peddle would stick when i was coasting & tried to apply a little gas). cleaning the throttle body resolved the problem completely (& improved mpg's by ~5). there's great instructions on this board here --> http://www.solaraguy.com/viewtopic.php? ... ottle+body
be sure when you buy throttle body cleaner, you get the type for FUEL INJECTED VEHICLES, do NOT use CARB CLEANER. CRC makes a pretty good cleaner for the TB. it should only set you back ~$5/can (you need <1/2 can for TB flush).
while you have the intake apart, you might also want to clean your MAF (you probably don't need to, but it doesn't hurt). CRC makes MAF cleaner that sells ~$5/can also (you only need a few sprays to clean the MAF).
& a big TY to solaraguy for having that info in tutorials for us.
mac-phisto
Postby MiistahSaan » Tue May 19, 2009 4:16 pm
it get stuck. but yeah. ill check out the tb. thanks
MiistahSaan
Postby RonnieBoi » Thu May 21, 2009 10:20 am
had the same problem, cleaned out the tb n it runs much smoother
99 slvr lara 4 cyl
blk leather
3 10s MTX with kickA$$ pioneer head unit
WR Dragon intake
18" enkei RSV bronze
RonnieBoi
