SolaraGuy.com • View topic - Doing timing belt and water pump. anything else?
Postby corlon » Thu May 21, 2009 8:09 pm
having the timing belt and water pump replaced on my 99 solara v6 with 119,000 miles. anything else i should have done while its apart?
NiCe
corlon
Re: Doing timing belt and water pump. anything else?
Postby RandySolara » Thu May 21, 2009 8:21 pm
corlon wrote:having the timing belt and water pump replaced on my 99 solara v6 with 119,000 miles. anything else i should have done while its apart?
Replace new Engine with Twin Cam Turbo lol joking, Belt and Pump are most important parts bro, if u like u can change Gas filter Spark plugs ,get new air filter its cheap.
U have Oil leaks maybe because u changed Belt&Pump ?
RandySolara
BAN sticked
Postby ASG14 » Thu May 21, 2009 8:32 pm
1: T Belt
2: Water Pump
3: Cam and crank seals
4: T Belt Tensioner
5: Accessory Belts
Thats the normal recommended stuff
ASG14
Postby Ilovemylara » Thu May 21, 2009 8:52 pm
Might want to check the valve cover gaskets, they tend to leak after 120k... mine did.
Postby corlon » Fri May 22, 2009 3:43 pm
just had the timing belt and water pump replaced. had a bad pressure switch, thats where the oil was leakng rom. had a friends service shop do it for 430.00 bucks. said all the other seals looked mint. ther old belt was stock and cracked to hell, which sucks. i just assumed the previous owner would have changed it at the regular interval. oh well, its done now.
NiCe
corlon
