SolaraGuy.com • View topic - corner lamps - got them open
Postby freshdenamufcka » Thu Jun 04, 2009 10:31 am
ok so after realizing that i probably wasn't going to find any blacked out corners i got bored and decided to open my corner lenses. i was able to pry them open withhout cracking anything. the lense actually came off pretty easy.
now my question is what part of the reflector should i paint black? and how do i seal it back again?
freshdenamufcka
Re: corner lamps - got them open
Postby Dawgz » Thu Jun 04, 2009 10:34 am
freshdenamufcka wrote:ok so after realizing that i probably wasn't going to find any blacked out corners i got bored and decided to open my corner lenses. i was able to pry them open withhout cracking anything. the lense actually came off pretty easy.
Tape off the oval part where the bulb shines thru, and paint the rest black,
U can seal it with Clear silicone (u can get it for 4-5 bux at pepboys).
Postby 1gSE » Thu Jun 04, 2009 10:39 am
http://www.amazon.com/1998-TOYOTA-SOLAR ... 092&sr=1-2 :wink:
but since you already went that far, i'm interested to see how they come out :D
Solara-M62 @ 5.5psi
1gSE
Postby freshdenamufcka » Thu Jun 04, 2009 10:42 am
the oval part actually comes off there are 2 clips holding it. what about the part where the amber piece was? on the aftermarket ones there is a clear reflector in place of the amber. do i just leave this chrome and paint around it?
freshdenamufcka
Postby freshdenamufcka » Thu Jun 04, 2009 10:45 am
1gSE wrote:http://www.amazon.com/1998-TOYOTA-SOLARA-CORNER-LIGHTS/dp/B000X2QS9W/ref=sr_1_2?ie=UTF8&s=automotive&qid=1244137092&sr=1-2 :wink:
those black corners are way too plain looking. the ones im trying to replicate are these
freshdenamufcka
Postby 1gSE » Thu Jun 04, 2009 11:24 am
aahh i see. :)
Solara-M62 @ 5.5psi
1gSE
Postby ~SolaRaSpeed~ » Thu Jun 04, 2009 11:27 am
you're probably going to have to buy a set of clear corners if you want that silver reflective piece. If you're trying to duplicate what you have in mind. I would see if the ones you want can be purchased first, but good luck if you want to go the DIY route.
~SolaRaSpeed~
Postby BLACK V6 » Thu Jun 04, 2009 11:32 am
You might be able to paint your old reflector a different color. What color is your car? if you have a white or red car I think it would look sweet painted the color of your car.
BLACK V6
Postby freshdenamufcka » Thu Jun 04, 2009 12:25 pm
BLACK V6 wrote:You might be able to paint your old reflector a different color. What color is your car? if you have a white or red car I think it would look sweet painted the color of your car.
yeah that was one of the ideas that i had in mind. might have to just play around with it to see what looks best with my car.
freshdenamufcka
