SolaraGuy.com • View topic - engine coolant flush?
Postby kubi » Wed Jul 16, 2003 9:16 am
toyota says to get your engine coolant flushed. is this the same as your radiator fluid? i would assume so, but i've been wrong before.
kubi
Postby TXSolaraSLE » Wed Jul 16, 2003 9:49 am
yup..the radiator is a major part of your coolant system. Engine coolant and radiator fluid are one and the same. there's a thread in DIY that gives details on how flush your engine coolant.
'99 Black Solara SLE
18" Mille Miglia Evo5
Yokohama AVS ES100
Indiglo Gauges
Kicker KSR100
K&N Filter
Xenon Headlights & License plate bulbs
TXSolaraSLE
Postby onefiend » Wed Jul 16, 2003 3:51 pm
how often do we need to flush the radiator/coolant? 1nce a year? every 30,000?
onefiend
Postby TXSolaraSLE » Wed Jul 16, 2003 4:05 pm
toyota schedules the engine coolant flush for every 30K miles. here's a link to a service schedule: http://www.jamestoyota.com/rec_service_print.html
Yokohama AVS ES100
Indiglo Gauges
Kicker KSR100
K&N Filter
TXSolaraSLE
Postby STR8PYP » Wed Jul 16, 2003 6:47 pm
Doh! I'm overdue. :)
SC
STR8PYP
Engine Flush??
Postby Solaraman » Sun Mar 14, 2004 1:43 am
I'm a little confused with some terminology. Is an Engine Flush the same as a Coolant Flush or does it include other things?
Solaraman
Postby Hsakuragi » Sun Mar 14, 2004 2:11 am
i just did it today, just 20 miles over 30k,somehow i only can found the front engine block plug, i can't seem to find the rear one.
So i drained out the from the radiator plug and the front engine block.
After the coolant was out, filled with plain water, flushed out the water then refilled the red coolant. It took 1 bottle of OEM coolant, then i filled with water into the empited bottle so it can be 50/50. But somehow while i put into half of the water, then it's full. (it doesn't seem to be 9.2 at all!)
So anyway, i tried to test drive it, and then i heard this water flusing noise in the car whenever i hit gas from stop.
Anyone know why?
Hsakuragi
Postby onefiend » Sun Mar 14, 2004 5:48 pm
hsakuragi wrote:It took 1 bottle of OEM coolant, then i filled with water into the empited bottle so it can be 50/50. But somehow while i put into half of the water, then it's full. (it doesn't seem to be 9.2 at all!)
Anyone know why?
1 entire bottle? isnt that too much?
onefiend
Postby 20SoLaRa02 » Sun Mar 14, 2004 9:47 pm
isn't oem coolant 50/50 already? the red stuff i just bought is. also the guy told me i might need a little more than one container.
-michael
20SoLaRa02
Re: Engine Flush??
Postby TRD MCV20L » Mon Mar 15, 2004 2:21 am
Solaraman wrote:I'm a little confused with some terminology. Is an Engine Flush the same as a Coolant Flush or does it include other things?
the engine flush cleans out the engine before you change your oil. i guess to reduce the sludge
the coolant flush i guess preps the radiator for the new coolant. i used it in my car but i didnt notice any differece. i dont think its a big deal to use the coolant flush
TRD MCV20L
Postby TRD MCV20L » Mon Mar 15, 2004 2:22 am
20SoLaRa02 wrote:isn't oem coolant 50/50 already? the red stuff i just bought is. also the guy told me i might need a little more than one container.
-michael
the toyota red is a straight coolant. you have to mix in the water yourself
TRD MCV20L
Postby Jai_Jai_Binks » Mon Mar 15, 2004 9:54 am
Just to be on the safe - i do my radiator flush before every summer every year! I know the red toyota coolant is good for three years..and this might be an overkill...but it did the same on my celica..and for being a 14 yr old car...there was NOTHING that was changed on the cooling system (minus the hoses at 10 yrs and the coolant yearly). It never overheated ever!
Postby Stock Solara SEV6 » Mon Mar 15, 2004 3:56 pm
hsakuragi wrote:i just did it today, just 20 miles over 30k,somehow i only can found the front engine block plug, i can't seem to find the rear one.
Anyone know why?
Might be some air in the system now. Since it's hard to get every last drop out of the system, I would suggest flushing the system with water until it runs clear out of the car (with the car running and a hose feeding the radiator). Next drain out all of the water you can, then add the amount of antifreeze that is equivalent to 50% of the capacity of the system, then finish filling with water. This way you get the proper 50/50 mixture.
2001 V6 5-speed
Stock Solara SEV6
Postby krook » Mon Mar 15, 2004 8:34 pm
in the Haynes manual it says to remove the temperature gauge in order to flush the system. is this necessary, or not really?
krook
Postby TRD MCV20L » Mon Mar 15, 2004 10:21 pm
krooked Solara wrote:in the Haynes manual it says to remove the temperature gauge in order to flush the system. is this necessary, or not really?
dunno. but when i flushed the system i waited for the thermostat to open up first
TRD MCV20L
Users browsing this forum: Google [Bot] and 32 guests
