SolaraGuy.com • View topic - Intake Manifold Removal/Injector Removal.
Postby burnyd » Thu Jun 11, 2009 10:57 am
Hi I have not made many posts on this forum unfortunately :( , but anyways I need some help here... I DD A 99 Solara 1mz powered! I normally go by the BGB For my mr2 / celica issues in the past but unfortantely I was unable to find a write up or any formal information on Pulling a Intake mani off of a 1mz.
I originally had a Miss fire on cyl #1, replaced the plug and wire still have the miss fire... When I pull the Injector out of cy #1 it does nothing still miss fires.... When I pull the injector out of any other Cyl the motor just about Dies... so clearly, cly#1 is bad... I am wondering if anyone has a write up, possibly access to a bgb to taking the upper intake manifold off to get access to that #1 Fuel injector.
thanks.
burnyd
Postby akora12 » Thu Jun 11, 2009 12:00 pm
I think your asking how to remove the intake plenum, not manifold. The TB has to come off along with the 2 chamber stays in the rear. The installation guide for the TRD supercharger in the link below has the info you need to remove the factory plenum.
http://www.solaraguy.com/viewtopic.php? ... hlight=trd
Postby burnyd » Thu Jun 11, 2009 1:19 pm
great thanks that is a big help... only problem is its really hard to read... any chance anyone has the PDF Version?
burnyd
