SolaraGuy.com • View topic - check engine light... help *P0446*
Postby SolaraMan7890 » Sat Jun 13, 2009 10:49 am
Ok so my check engine light turned on. went to autozone. I don't have the code, but it said something about fault CCV Solenoid. Anybody have any clue what that could be? :-?
2000 SE.
SolaraMan7890
Postby ASG14 » Sat Jun 13, 2009 10:51 am
Go back, get the code, post it up.
ASG14
Postby SolaraMan7890 » Sat Jun 13, 2009 11:06 am
Pretty sure it was PO446...
2000 SE.
SolaraMan7890
Postby SolaraMan7890 » Sat Jun 13, 2009 11:13 am
http://www.toyotanation.com/forum/t140285.html
^^^^^^I found that... but idk if its the same as our cars..
2000 SE.
SolaraMan7890
Postby SolaraMan7890 » Mon Jun 15, 2009 4:41 pm
Anyone?
2000 SE.
SolaraMan7890
Postby krook » Mon Jun 15, 2009 4:55 pm
the EVAP code 0446 is the same as our cars (as listed in the OBDII Trouble Codes Section in the Tutorial Forum)
as suggested by the thread you pulled up, did you check the gas cap?
that's a pretty simple check, if it's not that, maybe check some of your vacuum hoses under the hood.
krook
Postby SolaraMan7890 » Fri Jun 19, 2009 8:04 am
The cap is fine. I actually reset the system because I need to pass inspection by the end of the month. The light hasn't come on yet and ive driven about 70 miles... i'm going to try to bring it in after about 100 miles and see if they pass it, then if it comes back ill start pulling and replacing.
2000 SE.
SolaraMan7890
Postby SolaraMan7890 » Sun Jun 21, 2009 6:52 pm
after about 100 miles the light has come on again... I dont know what it is... going to take in to Toyota tomorrow :(
2000 SE.
SolaraMan7890
Postby SolaraMan7890 » Tue Jun 23, 2009 6:33 am
Replacing Charcoal canister and some valve that got messed up with it. $700 from Toyota fellas :(
2000 SE.
SolaraMan7890
