SolaraGuy.com • View topic - on another note - I'm throwing codes again
Postby redgen1 » Tue Jun 16, 2009 6:09 am
P0440 -> P0441 -> P0446
Check engine light came on this morning during my commute to work. All to do with the charcoal canister - I had it happen last year, reset it and didn't have any issues. Anyone have any ideas as to whats causing this or how to fix it?
02 SLE V6
Kaizen *constant improvement*
redgen1
Postby jetbtkng » Tue Jun 16, 2009 8:41 am
get a bag of kingsford................ :drinking:
Postby redgen1 » Tue Jun 16, 2009 8:49 am
will matchlight work? :wink:
02 SLE V6
redgen1
Postby SolaraMan7890 » Sun Jun 21, 2009 6:51 pm
i was going to post on the P0446 thread i made but then i saw this one. My light just went on again too. I have the p0446 code too. Charcoal canister. I reset it also and after about 100 miles it lit up again. I need a solution ASAP because I need to pass inspection before this month is over. I was planning on taking it to Toyota tomorrow.
2000 SE.
SolaraMan7890
Postby redgen1 » Sun Jun 21, 2009 6:55 pm
last year when this issue arose i think i replaced the charcoal canister. this time i reset it, 500+ miles ago now, and it hasn't turned back on
02 SLE V6
redgen1
Postby SolaraMan7890 » Sun Jun 21, 2009 6:58 pm
How much did a new charcoal canister cost?
Some guys are saying to replace the gas cap.
2000 SE.
SolaraMan7890
Postby SolaraMan7890 » Sun Jun 21, 2009 7:01 pm
2000 SE.
SolaraMan7890
Postby RandySolara » Mon Jun 22, 2009 10:40 am
Sorry for a noob question, how do u guys get the code when the CHECK LIGHT Engine on ? how do u know exactly the code showed up ?
RandySolara
BAN sticked
Postby Pogs » Mon Jun 22, 2009 10:42 am
RandySolara wrote:Sorry for a noob question, how do u guys get the code when the CHECK LIGHT Engine on ? how do u know exactly the code showed up ?
Advanced auto parts will tell you for free.. There are also OBDII(?) scanners to help you determine the code and clear them.
Search and Win
Pogs
Postby RandySolara » Mon Jun 22, 2009 8:44 pm
Im from Canada, maybe Stephen Harder will tell me and clear out the code for free :D
RandySolara
BAN sticked
Postby GreenSolara01 » Mon Jun 22, 2009 8:49 pm
How are your lines? thers like 5 or six that go back and forth between the tank, motor, evap ....
Have you removed the plastic cover and checked all the evap lines.
Also I think there are two lines that go to you intake my lower one came off once and I through 440.
This might sound stupid but when was the last time you checked the gasket on your fuel cap? It will keep all that gas vapor in and dust dirt out.
GreenSolara01
Postby SolaraMan7890 » Tue Jun 23, 2009 6:35 am
My P0446 was the Charcoal Canister and unfortunately a valve went with it. $700 from Toyota.
I was better off with the kingsford...... lol
2000 SE.
SolaraMan7890
Postby Midias » Tue Jun 23, 2009 9:25 am
Mine was the valve on top of the canister. For my wife I am not sure but it turns off during the winter and I get it inspected then.
