SolaraGuy.com • View topic - Changing brake shoes
Postby mazen222 » Sun Jun 21, 2009 8:41 am
My E-brake is more than dead now... its even making a scratching noise when the car is rolling.
I'm buying the shoe "pads" online and i would like to replace them myself. Is there a tutorial out there that can help me out?
I would also want to know how to tighten the brake lines... i heat its under the brake handle.
Thanks for any tips,
Mazen
1999, 5 Speed V6
mazen222
Postby Mole » Sun Jun 21, 2009 8:44 am
you should adjust by the drum. there is a hole and a sprocket inside around the 6 o clock position?? (been a while)
forgot which way to rotate the sprocket...
eh.. pictures here to give you an idea, (not solara though)
http://g35driver.com/forums/brakes-susp ... sedan.html
Postby campfire9 » Sun Jun 21, 2009 10:30 am
Here are a couple of links that should help. The first is for the E-brake only and the second is the maint manual for the Gen 2 Solara that has been floating around for some time. The E-brake section is part of the manual.
http://cns-design.ru/files/solara/pdf/P ... 0Brake.pdf
http://www.solaraguy.com/viewtopic.php?t=35384
Hope this helps.
Without ammunition, the USAF would be just another very expensive flying club.
campfire9
Postby aenties » Sun Jun 21, 2009 5:23 pm
To adjust your ebrake.
Turn off ebrake. There's a hole in your rotor, rotate it to 6 o clock and you'll see the star. Using a flat head, turn the star upwards until you can't spin the rotor anymore. Then BACK OFF 8 notches (meaning turning the start downward 8 notches). Do this to both side. You might here some noise for a bit when you drive off but this is normal for the shoe to wear down a bit.
'98CamryLEV6:
Tokico,Eibach,TrdRSB,Intake,Jim'sTorqueRod.
aenties
Postby mazen222 » Mon Jun 22, 2009 9:36 am
thx guys, this will deff help
1999, 5 Speed V6
mazen222
