SolaraGuy.com • View topic - Newly Acquired Solara... First tank of fuel ~ 16mpg HELP
Postby ampreston85 » Sun Jun 21, 2009 3:49 pm
Alright, so i finally filled the tank for the first time... I'm about to E, and only @ 300 miles to the tank. Simple math tells me that i have gotten no better then 16.5 mpg average (18.5 gallon tank). This is very upsetting, especially knowing that my POS Neon got 22 mpg average and it was POS on wheels lol. Everything is stock, it's a V6 SE of course, and i use Mobile 5000 synthetic blend oil. I'm wondering what needs to be addressed. Tune up maybe? I know it's a V6 but i should be at least 22 - 25 mpg average considering at least half my drive is freeway to work n back. Wondering if new spark plugs, spark plug wires will help... What else? And also wondering how much a Injen SRI will help in the matter as well. Your feedback is much appreciated!
ampreston85
Re: Newly Acquired Solara... First tank of fuel ~ 16mpg HELP
Postby Dawgz » Sun Jun 21, 2009 3:52 pm
ampreston85 wrote:Alright, so i finally filled the tank for the first time... I'm about to E, and only @ 300 miles to the tank. Simple math tells me that i have gotten no better then 16.5 mpg average (18.5 gallon tank). This is very upsetting, especially knowing that my POS Neon got 22 mpg average and it was POS on wheels lol. Everything is stock, it's a V6 SE of course, and i use Mobile 5000 synthetic blend oil. I'm wondering what needs to be addressed. Tune up maybe? I know it's a V6 but i should be at least 22 - 25 mpg average considering at least half my drive is freeway to work n back. Wondering if new spark plugs, spark plug wires will help... What else? And also wondering how much a Injen SRI will help in the matter as well. Your feedback is much appreciated!
Spark plugs, plug wires, a good treatment of Sea foam, Clean out the Throttle body, clean the MAF with CRC MAF cleaner. Tire pressure set to correct psi....also depends on how you drive (lead foot vs conservative). Another thing you could try is some injector cleaner in the tank.
Postby Garrryyunit » Sun Jun 21, 2009 4:34 pm
what he said. haha
Photo My Car
2002 Solara SE - Sold
1992 Civic VX - Current
2003 S2000 - Current
Garrryyunit
Postby cklinh » Sun Jun 21, 2009 4:40 pm
Did you actually see the pump say 18.5 gal?
cklinh
Postby ampreston85 » Sun Jun 21, 2009 5:13 pm
Ha no... thats how big the tank is... it hit 17ish @ the pump. and the light had just come on when i filled it... now i have the light on for about the last 15 miles... and im barely @ 305 miles.
ampreston85
Postby unbalancedwood » Sun Jun 21, 2009 6:00 pm
I would say tune up also.
If you want just remove one of the spark plugs (check the tutorial section) and see what it looks like. Did you get any records when you bought it?
seafoam works good too...do it before you change the plugs though, then change the plugs after a tank goes through. I also do the seafoam 500miles before i change my oil...
Ive gotten an average of 25-30 highway with easy driving...
unbalancedwood
Postby SleeperSolara » Sun Jun 21, 2009 7:11 pm
Do what "Dawgz" suggested.
That will help your MPG's.
Gettin' an SRI will decrease your MPG's by alittle bit.
It also depends on how hard you drive your car also.
Postby mazen222 » Mon Jun 22, 2009 9:39 am
i should do that tune up too...
1999, 5 Speed V6
mazen222
Postby NightRider » Mon Jun 22, 2009 6:38 pm
Dawgz wrote:Spark plugs, plug wires, a good treatment of Sea foam, Clean out the Throttle body, clean the MAF with CRC MAF cleaner. Tire pressure set to correct psi....also depends on how you drive (lead foot vs conservative). Another thing you could try is some injector cleaner in the tank.
I agree w/ him. He pretty much said what I was thinking as well.
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby GreenSolara01 » Mon Jun 22, 2009 8:16 pm
http://www.solaraguy.com/viewtopic.php? ... highlight=
ha dsame problem. try to use the search tool at the top of the screen so we don't have so many dup posts
Thanks and good luck
GreenSolara01
Postby Chinky420 » Mon Jun 22, 2009 9:32 pm
do you have a CEL right now?
driving with a CEL (or maybe only certain CELs) will make your car run rich....the ecu keeps the car in a warmup loop......one of the side effects is that your gas mileage goes down. right now, with a CEL i'm getting around 250miles/tank - 330 miles/tank depending on if it's city driving or highway.
those numbers basically boil down to approx 17 - 22 mpg....which is less than ideal, but consistent and predictable with my situation.
Chinky420
Postby Chinky420 » Mon Jun 22, 2009 9:33 pm
oh yeah, i also have a lead foot...which effects mpg too.
Chinky420
Postby lexmex » Tue Jun 23, 2009 8:08 am
The more constant you keep your foot on the accelerator (meaning use cruise control when you can or staying at the same velocity), the greater the mpg. Cleaning the IACV valve can also help. Also examine your air filter.
lexmex
Postby RandySolara » Tue Jun 23, 2009 8:34 am
lexmex wrote:The more constant you keep your foot on the accelerator (meaning use cruise control when you can or staying at the same velocity), the greater the mpg. Cleaning the IACV valve can also help. Also examine your air filter.
Air filter n Gas filter too >?
RandySolara
BAN sticked
Postby SolaraMan7890 » Tue Jun 23, 2009 10:37 am
I get 360 miles a tank... on average, and usually run it to til the E light comes on, at which point I force in roughly 16.3 gal... hmmm
2000 SE.
SolaraMan7890
