SolaraGuy.com • View topic - Keyless Remote Programing ! i really need help please.
Postby RandySolara » Thu Jun 25, 2009 8:16 pm
How do i program the keyless remote for my 2nd remote ? i bought the keyless remote from this guy but this one is for solara 99 SLE V6, DOES IT WORK WITH Solara 2001 SLE V6 ? passed by my mechanic today he spent an hour but it did not work out, she said he specialized in Honda Acura Nissan Infiniti wat dah heck LOL.
I just dont wanna bring it to the dealer, i believe Solara Guys can help me out, my son was playing with the Key n the remote and then he dumped it to the garbage, could not find it, thanks so much for the help guys.
RandySolara
BAN sticked
Postby Ilovemylara » Thu Jun 25, 2009 8:36 pm
Start with drivers door open, unlocked, and no key in the ignition.
Insert and remove the key from the ignition switch twice within 5 seconds.
close and open the driver door twice within 40 seconds.
Then insert the key into the ignition key cylinder and remove it.
Close and open the driver door twice within 40 seconds.
Then insert the key into the ignition key cylinder and close the door.
Turn the ignition switch from LOCK to ON and back once and remove key
Locks should cycle once.
Within 40 seconds press the LOCK and UNLOCK switches on the transmitter switch simultaneously for 1.0 – 1.5 seconds.
Within 3 seconds after the previous operation, press either one of the switches for more than 1.0 seconds.
Within 3 seconds after the transmitter switch has been turned OFF, the LOCK–UNLOCK operation will be automatically performed once if the registration of the recognition code of the transmitter is completed correctly.
In case the LOCK–UNLOCK operation is performed twice, the registration of recognition code has failed.
Perform the registration procedure from the beginning once again.
Postby RandySolara » Fri Jun 26, 2009 10:54 am
Thanks so much ilovemylara, apreciated !
RandySolara
BAN sticked
Postby Ilovemylara » Fri Jun 26, 2009 2:31 pm
Did it work?
Postby RandySolara » Fri Jun 26, 2009 8:43 pm
Ilovemylara wrote:Did it work?
Did not work bro, is there another way ?
RandySolara
BAN sticked
Postby Ilovemylara » Fri Jun 26, 2009 8:55 pm
Sorry those instructions were for the gen 2, these below are the correct instructions for the gen 1
1. Start with the following conditions:
a. Key Is out of the ignition.
b. Driver door is open (all other doors are closed).
c. Driver door is unlocked (other door locks don't matter).
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. Using the power lock/unlock switch on the driver's door, perform 5 lock/unlock cycles starting with lock. A
lock/unlock cycle consists of pressing the power lock switch, followed by pressing the power unlock switch on the driver's door panel. Use an even pace and try to go relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. Using the power lock/unlock switch on the driver's door, perform 5 lock/unlock cycles starting with lock (just as
you did previously).
b. Turn the ignition to ON (as far as you can go without cranking your engine), then back to OFF.
c. Turn the ignition to ON (as far as you can go without cranking your engine), then back to OFF.
d. Remove the key from the Ignition.
5. Within 3 seconds, the power door locks should cycle (lock then unlock) automatically Indicating successful entry into
programming mode. Return to Step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a. Press the lock and unlock buttons on the transmitter simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons, hit the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle (lock then unlock) once indicating successful programming. If the
door locks don't cycle, or cycle twice, repeat steps 6a and 6b - this remote has not been accepted.
c. Repeat steps 6a and 6b for each transmitter that will operate the vehicle, including any old transmitters.
7. Close driver door.
Postby Ilovemylara » Fri Jun 26, 2009 9:00 pm
I know these are complicated and may not work the first time, but if done correctly, this WILL WORK.
Postby RandySolara » Fri Jun 26, 2009 9:10 pm
Ilovemylara wrote:I know these are complicated and may not work the first time, but if done correctly, this WILL WORK.
Thanks again bro, you've spent too much time on this, i will try it tomorrow, no wonderin it didnt work, that one is gen2.
RandySolara
BAN sticked
Postby Ilovemylara » Fri Jun 26, 2009 9:17 pm
no problem man.. Just helpin out a fellow s.g.-er :)
Postby RandySolara » Sat Jun 27, 2009 11:07 pm
Ilovemylara wrote:no problem man.. Just helpin out a fellow s.g.-er :)
Hey brother, it worked perpect with 1 try, thanks again, but i encounter an issue, when i activate my new remote, the old remote automatically Deactivate, new one works n old one stop work lol, is my car or my remote has problem ? or Solara 2001 only accept 1 remote n key ? very funny.
RandySolara
BAN sticked
Postby D-money » Sat Jun 27, 2009 11:52 pm
D-money
Postby RandySolara » Sun Jun 28, 2009 12:03 am
Oh my god lol, i was so happy when it worked n i forgot to read the very bottom line,,,hahahah thanks bro, the guy in Toyota suks, he told my mech different ways n never worked, ur code dam i did myself with 1 try :) ur the best bro.
RandySolara
BAN sticked
Postby Ilovemylara » Sun Jun 28, 2009 12:06 am
Glad you got it figuired out man! :)
Postby RandySolara » Sun Jun 28, 2009 11:34 pm
Ilovemylara wrote:Glad you got it figuired out man! :)
Got it all done this afternoon bro, million thanks again.
The Mech i just knew he didnt know much about Solara, he even asked his other mech n they gave all wrong info. Probably for Camry or Corrola.
RandySolara
BAN sticked
Postby djandrey_M » Sun Oct 04, 2009 9:24 pm
I tried it. The locks don't cycle (which means the car is not entering the programming mode.)
Can anybody help me before I start forking over money to car alarm places?
djandrey_M
