SolaraGuy.com • View topic - Clock not working
Clock not working
Clock not working
Postby Guest » Thu Jul 17, 2003 6:46 pm
The dashboard clock and the inside lamp are not working ever since I had a car wreck? any idea?
Guest
Postby hari-bhari » Thu Jul 17, 2003 7:45 pm
check the fuse box, its behind the coin holder under the steering wheel to the left. u may just have a blown fuse. the diagram for what fuse is for what devices is located on the back of the coin holder. make sure u replace the fuse with another one rated at the same amperage (A) or lower (if its an emergency), but never higher.
hari-bhari
Postby Blaze » Thu Jul 17, 2003 8:32 pm
if that doesnt work, have they ever taken your dash apart? The cables might not have been plugged back in.
Blaze
Postby Yanks0114 » Thu Jul 17, 2003 8:48 pm
Blaze wrote:if that doesnt work, have they ever taken your dash apart? The cables might not have been plugged back in.
Thats my guess. Its really easy to reconnect it, just one harness
Postby xyntax » Thu Jul 17, 2003 11:07 pm
Good way to test the circuit is via the Cig socket. This happened to me once when I burned a fuse. I think the clock shares the same connection as those electronic things on the center dash except for the radio.
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby Guest » Fri Jul 18, 2003 8:21 am
There is a fuse box right next to the battery that has 2 missing fuses.
That might be causing the problem.
Guest
Users browsing this forum: Google [Bot] and 31 guests
