SolaraGuy.com • View topic - Gen. 1 V6 rattle noise
Postby FFguy808 » Thu Jul 02, 2009 10:11 pm
My Solara has this rattling sound (sounds like small bits rattle) when accelarating...doesn't have this sound when park and I rev the engine..I only notice it in accelaration..
anybody has this problem or is just normal?
FFguy808
Postby D-money » Thu Jul 02, 2009 10:13 pm
its called chatter usually caused by cheap gas or low oil
D-money
Postby FFguy808 » Thu Jul 02, 2009 10:32 pm
I use Shell 91 octane gas plus octane booster additive every fill up and my oil is at the correct oil level... :lol:
FFguy808
Postby corlon » Thu Jul 02, 2009 11:05 pm
i got a rattle / buzz noise under hard acceleration after a cpe intake install. come to find its the cowl piece at the base of the windshield vibrating. check that maybe?
NiCe
corlon
Postby RandySolara » Thu Jul 02, 2009 11:52 pm
thats normal my friend, the vibration may cause something to sound like that when u accelabrate.
1, Engine strong 2, Engine shaking
Thats why u sometimes hear that after install SRI CAI or CP-E Intake, more power more sound lol
I usually hear that noise after i do tune-up oil,air filter, n Super Fuel changes. Check under ur hood see if some bolt is losen, tighten it.
RandySolara
BAN sticked
Postby nemoxfishy » Fri Jul 03, 2009 1:06 am
I have the same rattling sound too. I think we're fine.
nemoxfishy
Postby FFguy808 » Fri Jul 03, 2009 1:33 am
gon check out the exhaust bolts tomorrow and the rear exhaust manifold...
FFguy808
Postby mazen222 » Fri Jul 03, 2009 5:42 am
if you dont hear it when parked nor when you rev, then its something related to the wheels.
check your parking brake... try to pull it a pit when you're rolling slowy to see if it stops
1999, 5 Speed V6
mazen222
Postby GzNutz » Fri Jul 03, 2009 6:55 am
I've got a rattling heat shield on my cat right now. When in park or neutral there is not enough vibration to get a rattle, but once the transmission is engaged the rattle begins. Is the rattle metal on metal, like sheet metal slapping?
Postby FFguy808 » Sat Jul 04, 2009 8:00 pm
on mines, they sound like small coins hitting each other...only happens while im driving with the gas pedal pressed...
FFguy808
Postby gnegroni » Sat Jul 04, 2009 8:14 pm
FFguy808 wrote:on mines, they sound like small coins hitting each other...only happens while im driving with the gas pedal pressed...
I have some of this on my Gen2 manual, but only if I'm revving past 4,500 rpm and such.
gnegroni
Postby D-money » Sat Jul 04, 2009 8:16 pm
are you able to take a video? it would sure help
D-money
Postby Ilovemylara » Sat Jul 04, 2009 8:24 pm
Ahh.. that sounds like pinging... I run 93, but in the sumer my car always does it. The warmer air from summer being here will cause your engine to ping alot more.
