SolaraGuy.com • View topic - Noise from TB cover
Noise from TB cover
Noise from TB cover
Postby decavo » Sat Jul 04, 2009 5:26 pm
My timing cover has a rattle coming from it. The belt, seals pump was changed out about 40 k ago. I have this sound for 6 months now. Should I be freaking out and what should I be repairing.
Thanks in advance.
D
2000 black 4cyl 130k total stocker all original
1991 80 Land Cruiser air lockers, tube bumper, rhino-lined 165K
decavo
Postby lilm » Sat Jul 04, 2009 5:59 pm
tighten it?
lilm
Postby 5sfe » Sat Jul 04, 2009 6:24 pm
does it rattle when your idling or when the car is under load/moving?
5sfe
Postby D-money » Sat Jul 04, 2009 7:57 pm
lilm wrote:tighten it?
X2 no big deal
D-money
Postby decavo » Sat Jul 04, 2009 9:49 pm
5sfe wrote:does it rattle when your idling or when the car is under load/moving?
When it is idling, while driving I really can not hear it.
decavo
Postby decavo » Sat Jul 04, 2009 9:50 pm
It seems the noise is from with in. When I wiggle the cover it does not change the rattle.
decavo
Postby ASG14 » Sat Jul 04, 2009 9:54 pm
You can't "tighten" the damn belt....
Ddi you replace the tensioner for the Timing Belt?
ASG14
Postby D-money » Sat Jul 04, 2009 10:04 pm
ASG14 wrote:You can't "tighten" the damn belt....
I think we where talking about the cover
D-money
Postby decavo » Sun Jul 05, 2009 5:32 am
I did not do the work when the belt was replaced, so I have no idea. It was done at a toyo shop no the stealership. When the work was done I told them to replace what ever they could while in there.
decavo
Postby Chinky420 » Mon Jul 06, 2009 1:59 pm
is it a uniform rattle (like the rattle stays constant at different RPMs?)
does the rattle correlate to engine revs (rev up the engine, and the rattles increase with it)?
is 'rattle' the best word for it, or would 'ticking' also be an adequate description of the sound?
if it's not the timing cover, then maybe the valves need adjustment?
any other symptoms? oil leaking? boggy engine? or does everything else work fine, except it sounds bad?
Chinky420
