SolaraGuy.com • View topic - Keyless Remote Question
Postby mers714 » Sun Jul 05, 2009 10:14 pm
I purchased my 2000 Solara V6 SE last month and it only came with a key and no keyless entry remote. There's a security light on the cluster that blinks. How do i go about getting a remote or programming it?
Thanks
-blake
mers714
Postby D-money » Sun Jul 05, 2009 10:48 pm
they sell them on ebay http://cgi.ebay.com/ebaymotors/Toyota-C ... ccessories
it comes with program instructions
D-money
Postby mers714 » Sun Jul 05, 2009 10:57 pm
thanks for the reply
i found my old toyota matrix remote, would it work? It has the same FCC ID
same as this one
http://cgi.ebay.com/ebaymotors/2000-04- ... |72%3A1171
mers714
Postby ampreston85 » Sun Jul 05, 2009 11:04 pm
Also, make sure it doesn't have an aftermarket alarm that you don't know about lol... I got my lara a month ago, and they didn't say that it had aftermarket alarm. I took it to a local car stereo/accessory shop and they programmed a remote to it for free, just had to pay for the remote. Look under the hood driver side all the way up by the windshield.... thats usually where the aftermarket alarms are installed.
ampreston85
Postby D-money » Sun Jul 05, 2009 11:11 pm
mers714 wrote:thanks for the reply
same as this one
you could try to program it ,it wont hurt anything read all the way through this thread it will tell you how http://www.solaraguy.com/viewtopic.php? ... ess+remote
D-money
Postby mers714 » Sun Jul 05, 2009 11:33 pm
just tried it, no luck. maybe i'm doing it wrong....
mers714
Postby D-money » Sun Jul 05, 2009 11:51 pm
you tried this ? 1. Start with the following conditions:
a. Key Is out of the ignition.
b. Driver door is open (all other doors are closed).
c. Driver door is unlocked (other door locks don't matter).
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. Using the power lock/unlock switch on the driver's door, perform 5 lock/unlock cycles starting with lock. A
lock/unlock cycle consists of pressing the power lock switch, followed by pressing the power unlock switch on the driver's door panel. Use an even pace and try to go relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. Using the power lock/unlock switch on the driver's door, perform 5 lock/unlock cycles starting with lock (just as
you did previously).
b. Turn the ignition to ON (as far as you can go without cranking your engine), then back to OFF.
c. Turn the ignition to ON (as far as you can go without cranking your engine), then back to OFF.
d. Remove the key from the Ignition.
5. Within 3 seconds, the power door locks should cycle (lock then unlock) automatically Indicating successful entry into
programming mode. Return to Step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a. Press the lock and unlock buttons on the transmitter simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons, hit the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle (lock then unlock) once indicating successful programming. If the
door locks don't cycle, or cycle twice, repeat steps 6a and 6b - this remote has not been accepted.
c. Repeat steps 6a and 6b for each transmitter that will operate the vehicle, including any old transmitters.
7. Close driver door.
D-money
Postby mers714 » Mon Jul 06, 2009 12:51 am
yeah i tried that it didnt work, ill try it again tomorrow if it doesnt work again ill just buy the one on ebay you posted and see if that works
thanks for your help
mers714
Postby reance » Tue Jul 28, 2009 5:12 am
Hi
We offer a wide selection of original manufacturer keyless entry remotes (RKE, fobs) at discount prices. In most cases you can also program the remote yourself with our easy to follow programming instructions. Please visit our website at
http://www.carandtruckremotes.com/
If you have any questions or have any specific inquiries about your remote system please contact us at customercare@carandtruckremotes.com including year, make and model of your vehicle.
You can also view our FAQ page for answers to common questions. Link below
http://www.carandtruckremotes.com/faq.html
Best Regards
reance
Postby SolaraMan7890 » Tue Jul 28, 2009 7:15 am
Would this work on all Solaras? because I purchased an ebay remote and then I tried to do this programming thing multiple times but it never worked. I was told my car never came with automatic keyless entry. I just find this hard to believe because when i leave the key in the ignition and i open the door and try to lock the car, the car AUTOMATICALLY unlocks them...
2000 SE.
SolaraMan7890
Postby Pogs » Tue Jul 28, 2009 7:39 am
^^^ Thats a saftey measure all solaras have. I beleive you need the box to communicate with the remote. The saftey measure is essentially the same as power locks.
Search and Win
Pogs
Postby SolaraMan7890 » Tue Jul 28, 2009 8:40 am
Is there a way I can check if i have this "box" or how do I know I have keyless entry?
2000 SE.
SolaraMan7890
Postby Pogs » Tue Jul 28, 2009 8:47 am
I searched a while ago to see where it was located to see if i had one (I didnt).... Some threads say under the drivers seat, ive seen some say under the center console. Maybe do a search and get all your options.
Search and Win
Pogs
Postby GTX » Tue Jul 28, 2009 12:12 pm
D-money wrote:they sell them on ebay http://cgi.ebay.com/ebaymotors/Toyota-C ... ccessories
I just bought one of these for $15. Man I love this place.
99 Camry LE V6
GTX
Postby GTX » Sun Aug 02, 2009 2:08 pm
Soooo I got my remote in the mail today and I tried the programming procedure. Did it several times and it didn't work. Is there a trick to it, maybe a certain speed or pace I should be going? I really hope I didn't waste my money :-(
99 Camry LE V6
GTX
