SolaraGuy.com • View topic - Clutch pedal feels weird
Postby mazen222 » Mon Jul 06, 2009 4:03 am
After adjusting the clutch pedal height, and then bringing it back to the same height, it has been acting weird with me.
The adjustment i did was to unscrew the lock nut at the pedal and turning the screw shaft.
Now when i drive, the clutch feels very soft, as if there's almost no resistance when i press it and the friction point is at the bottom (the clutch engages as soon as i start raising my foot). But after 15 min of driving, the friction point become much higher and there is a good resistance, almost like a very strong spring that pushed the pedal upwards.
Any clues on whats going on? I've tightened the lock nut, so it shouldn't be that.
Thanks,
Mazen
1999, 5 Speed V6
mazen222
Postby mazen222 » Mon Jul 06, 2009 11:19 am
c'mon guys, where's all the pros here?
1999, 5 Speed V6
mazen222
Postby toytim » Tue Jul 07, 2009 5:33 pm
I don't have a solution to your problem but maybe the service manual has something in there. My clutch is kinda hard to push but it's a low mileage car so I don't think there's a problem...I did notice there is a spring on the clutch pedal and was wondering if I can adjust the tension. Did you try that? Tim
Happiness is a pair of Solara's!
toytim
Postby mazen222 » Tue Jul 07, 2009 6:31 pm
i dont think you can play with the spring... i spent quite sometime under there. My clutch was very soft, but now, after 15 min of driving, it becomes hard to push and i feel it pushing back much more when i release.
i still have no clue whats going on... im wondering if i have to bleed the system or something. i have the toyota repair manual for the clutch if u want to look into it, in pdf, let me know
1999, 5 Speed V6
mazen222
Postby Ilovemylara » Tue Jul 07, 2009 6:52 pm
mazen222 wrote:i dont think you can play with the spring... i spent quite sometime under there. My clutch was very soft, but now, after 15 min of driving, it becomes hard to push and i feel it pushing back much more when i release.
I would bleed and replace the fluid first to see if that is the cause.
Postby mazen222 » Wed Jul 08, 2009 3:58 am
how do i bleed the system? I have a feeling that this might fix it. It doesnt say how in the maintenance manual
1999, 5 Speed V6
mazen222
