SolaraGuy.com • View topic - New member new problems
Postby Reggy » Wed Jul 08, 2009 1:50 pm
Hello, I just purchased a 2000 Toyota Solara SLE and whenever I go over the smallest of bumps , a weird sound comes from the rear right area. The closest sound I can compare this to is a box of tools falling down the stiars. Outside of the sound theres no problems from the suspension so I have no idea if it is a shock , spring or some random panel thats loose. Any opinions on this problem would help. Thanks :cry:
Reggy
Postby yaddadaimsayin » Wed Jul 08, 2009 2:13 pm
it COULD be the tools that came loose by the spare. I was facing some clankin noises on the rear right the other day too and that's what my problem was. if not, then you might want to check the suspension.
welcome to SG.
Postby Ilovemylara » Wed Jul 08, 2009 2:14 pm
Welcome!
Postby ASG14 » Wed Jul 08, 2009 2:47 pm
Strut mount broken or loose sway bar link
ASG14
Postby bbq bob » Wed Jul 08, 2009 2:55 pm
welcome
bbq bob
Postby s15lara » Wed Jul 08, 2009 3:29 pm
x2 on the strut mount/sway bar link
almost there...what do you think?
s15lara
Postby Reggy » Wed Jul 08, 2009 3:35 pm
Thanks for the warm welcomes and help.
Reggy
Postby D-money » Wed Jul 08, 2009 5:28 pm
yaddadaimsayin wrote:it COULD be the tools that came loose by the spare. I was facing some clankin noises on the rear right the other day too and that's what my problem was. if not, then you might want to check the suspension.
welcome to SG.
Had the same issue and it ended up being the jack
D-money
Postby drewcrane » Wed Jul 08, 2009 5:33 pm
Had the same issue and it ended up being the jack ,me too!same noise 8)
"its a vanishing point thing you wont understand"
drewcrane
Location: 13.7 sec.s @bandimere ,5800 ft above sea level
Postby krook » Wed Jul 08, 2009 7:58 pm
oh frick...it's not that god-awful passenger seat track is it??
i hate that thing
krook
Postby D-money » Wed Jul 08, 2009 8:28 pm
krook wrote:oh frick...it's not that god-awful passenger seat track is it??
i hate that thing
Ive had my pass seat out so many times tryint to fix that rattle,What can be done??????????????
D-money
Postby Ilovemylara » Wed Jul 08, 2009 8:37 pm
i hate that thing
ME 2!!!! I dont know how to fix it. I think the problem is caused from the seat sliding forward really fast and slamming into the metal track stops when you lean it forward for people to get in/out of the back seats. I guess that it wears out the rollers or something.
Postby Reggy » Wed Jul 08, 2009 9:47 pm
I took the jack out and drove around the block and it was still making that sound , so i believe its the loose sway bar link or broken stut mount. Not to be a bother but I'm a novice when it comes to physical mechanics when purchasing a replacement strut mount / sway bar link should I just buy a replacement sway bar at the same time or should my rear sway bar be fine. Just wondering because this sound has been going on for the past 100 miles or so , so i dont imagine that m sway bar if it is the problem is in good shape. Thanks again.
Reggy
Postby yota » Wed Jul 08, 2009 9:48 pm
I had a similar problem and it was a strut mount. Welcome and good luck!
yota
Postby krook » Thu Jul 09, 2009 12:51 pm
Ilovemylara wrote:
D-money wrote:Ive had my pass seat out so many times tryint to fix that rattle,What can be done??????????????
yeah, it's definitely when you have to lean it forward for passengers...it's when you put it back and the seat stays in that upright position.
the only thing i've found to "remedy" it, is to lean the seat back a bit, and pull the seat forward a notch from that upward position. that does the trick.
krook
