SolaraGuy.com • View topic - Timing Belt question
Postby mers714 » Thu Jul 09, 2009 11:12 pm
Hello
I just purchased my solara about 2 months ago it has 145k miles on it and I dont know if the timing belt has been changed so im just going to change it. A mechanic quoted me 450 for timing belt, water pump, and the 2 other belts. Is this a reasonable price? thanks
-blake
2000 Solara V6 SE AUTO - TRD RSB - TINT - 6K HID's
mers714
Postby ampreston85 » Thu Jul 09, 2009 11:38 pm
IMO yes... Thats a pretty reasonable price. A lot of times you end up spending 5-6-7 hundred depending. But i would recommend pitching the extra few bucks and grabbing your own belts. Get Gatorbacks!
ampreston85
Postby mers714 » Thu Jul 09, 2009 11:43 pm
he said he would use toyota belts is that good enough?
mers714
Postby ampreston85 » Thu Jul 09, 2009 11:45 pm
Toyota always makes a good product... That or Gatorback will do good! I'm not sure but i believe the Gatorbacks have some time of warrenty/garrenty but i don't remember.
ampreston85
Postby mazen222 » Fri Jul 10, 2009 5:32 am
i bought my car used and didnt know if the timing belt was changed or not.
i put money asside to change it, but last min, i went to a mech and asked him if it needs to be changed, he said it looked almost new, so that saved me a good 500$.
Ask someone to inspect it first before u go ahead. i have almost the same milage as you do
1999, 5 Speed V6
mazen222
Postby Dawgz » Fri Jul 10, 2009 8:39 am
You cant really inspect a timing belt from the outside (as i was told). Sure u can LOOK at the belt from the outside but u cant really diagnose how much use is on it.
For instance, when king did the timing belt on my car i had 85k on the OD. The belt looked Spank'n new.
Btw, when you get this done, try to get the Crank seal and the tensioner changed as well....Dont skimp on the tensioner for sure.
Postby mers714 » Fri Jul 10, 2009 8:43 am
the mechanic looked at it and said there were cracks in it
im going today to get it changed
thanks for the help :D
mers714
Postby mazen222 » Fri Jul 10, 2009 10:21 am
mers714 wrote:the mechanic looked at it and said there were cracks in it
if there are no cracks on it doesnt need to be changed, thats what i was refering to when i was talking about inspection
1999, 5 Speed V6
mazen222
Postby ToyoSolV6 » Fri Jul 10, 2009 1:38 pm
out of the question, but Blake were you able to get the lights to work out for you man?
Postby mers714 » Fri Jul 10, 2009 2:48 pm
ToyoSolV6 wrote:out of the question, but Blake were you able to get the lights to work out for you man?
yup i just broke a bracket off my black ones and glued it on the new ones. it looks good and it holds up strong, thanks
mers714
