SolaraGuy.com • View topic - Corner light doesn't turn on...
Postby mazen222 » Sun Jul 12, 2009 10:57 am
my driver side corner light doesn't turn on anymore for some reason, the passanger side works fine,
the weird thing is that it works fine when i turn the blinker on, so the bulb is fine.
I checked the three wires that go into the socket of the bulb and they're all well plugged.
Once i opened the hood, and when i slamed it back to close it, the corner light turned on, but then turn off later that day.
I remember someone having that issue here in the past but i couldn't find their post.
Any help on this?
i would also be interested to know how to bleed my clutch fluid... my clutch pedal is acting weird
Thanks!
Maz
1999, 5 Speed V6
mazen222
Postby Ilovemylara » Sun Jul 12, 2009 11:19 am
I had the same thing happen to me. My corner light wouldnt turn on, but the turn signal worked just fine. Its the removable socket that the bulb sits inside. Mine got wet, and the rust ate though the metal contacts. I just bought one from a junk yard for like 5 bucks. easy fix.
Postby ToyoSolV6 » Sun Jul 12, 2009 2:06 pm
yeah man its not making proper contact, check out the bulb if anything just replace it.
Postby mazen222 » Sun Jul 12, 2009 2:21 pm
that removable socket looks almost new... i tried to clean it with a Q-tip but no luck
the bulb is fine since its blinking...
this sucks... i'll go to a junk yard and get that socket, thanks man
1999, 5 Speed V6
mazen222
Postby SleeperSolara » Sun Jul 12, 2009 2:55 pm
Try pryin' the little copper contacts up alittle more.
That should work.
Gen 4 Camry's have that problem in the rear brake light.
