SolaraGuy.com • View topic - Screeching noise when making hard left/right turn
Postby __KINGPIN__ » Sun Jul 12, 2009 2:44 pm
i have a gen 1 solara and when i turn the wheel fully to the left or the right, it makes a screeching noise. i think its coming from the breaks? im not fully sure
it only happens when i accelerate forward. doesnt happen in reverse
is it because of new breakpads? (dealer put them in a few days ago) :drinking:
__KINGPIN__
Postby Ilovemylara » Sun Jul 12, 2009 3:21 pm
Yup. New brake pads will do that. Give them some time to wear in.
Postby __KINGPIN__ » Sun Jul 12, 2009 3:39 pm
the thing is that the same noise occurred when i test drove the car with old break pads.
can it be something else other than the break pads?
__KINGPIN__
Postby Ilovemylara » Sun Jul 12, 2009 3:51 pm
Check power steering level. Other than that, your front end might be out of alignment.
Postby D-money » Sun Jul 12, 2009 3:54 pm
power steering pump belt is loose its slipping when under load
D-money
Postby ToyoSolV6 » Sun Jul 12, 2009 3:58 pm
Rotors maybe?
Postby solara90 » Sun Jul 12, 2009 4:20 pm
if your stopped and turn all the way does still squeal or just when moving?
02 solara 2az
solara90
Postby __KINGPIN__ » Sun Jul 12, 2009 4:57 pm
yeah. if the car is parked, and i turn the steering wheel all the way to either left or right and aceelerate, it still makes the squeeling/schreeching sound.
__KINGPIN__
Postby D-money » Sun Jul 12, 2009 5:50 pm
solara90 wrote:if your stopped and turn all the way does still squeal or just when moving?
I think he meant does it do it when the car is not moving?
D-money
Postby __KINGPIN__ » Sun Jul 12, 2009 7:24 pm
no, when the car is stopped and i turn the steering wheel hard left/right it doesnt make any noise.
only when its accelerating
__KINGPIN__
Postby ampreston85 » Sun Jul 12, 2009 10:55 pm
Lol my neon did that exact same noise right before the power steering pulley fell apart. well... not fell apart, but after doing that for a month or so, it finally threw the belt all together. After further examination, looks like the pulley had become loose.... ended up needing a new power steering pulley and pump.
ampreston85
Postby Mole » Sun Jul 12, 2009 11:20 pm
you're not doing a burnout right?
Postby LatinUSMC » Mon Jul 13, 2009 8:33 am
__KINGPIN__ wrote:yeah. if the car is parked, and i turn the steering wheel all the way to either left or right and aceelerate, it still makes the squeeling/schreeching sound.
ITS ONLY GONNA GET WORST AND LOUDER, ( IST A DRY OR OLD DRIVE BELT power steering , NEXT TO THE ANTIFEESE RESEVOIR) TAKE IT TO THE SHOP AND HAVE THE BELT REPLACED ,IT SHOULD COST NO MORE THAN 10 BUCK FOR THE BELT, ( NEANTIME THERES AN STP SPRAY TO LUBE UP THE BELT
sorry bout the caps
if you dont fix it you wount be able to turn( can be dangerous) i almost crashed into the sidewalk on my way to the shop cus i couldnt make a complete U turn.
:drinking:
LatinUSMC
Postby __KINGPIN__ » Tue Jul 14, 2009 8:55 pm
i think it was the new break pads
screeching seems to have stopped after a few days of driving
but il get it checked anyways
__KINGPIN__
