SolaraGuy.com • View topic - Royal Purple MAX ATF on Gen.1
Postby FFguy808 » Mon Jul 20, 2009 11:05 pm
Anyone running Royal Purple MAX ATF on their Gen.1 Auto Solara? Opinions?
I'am planning on changing my Dex ATF soon and just wanna know what kind of brand ATF you guys are running?
FFguy808
Re: Royal Purple MAX ATF on Gen.1
Postby Dawgz » Tue Jul 21, 2009 12:04 am
FFguy808 wrote:Anyone running Royal Purple MAX ATF on their Gen.1 Auto Solara? Opinions?
https://www.mobiloil.com/USA-English/Mo ... c_ATF.aspx
thats what i use.
Postby FFguy808 » Tue Jul 21, 2009 12:26 am
Any changes on the shifting..is it a lot smoother?
Amsoil is good but it is expensive here in hawaii...like $13/qt
FFguy808
Postby Mr_Chunkz » Tue Jul 21, 2009 1:11 am
i run royal purple max atf and have since increasing to 5.5 psi
i change it every 4k miles cause of my extremely abusive driving habits
it never ever looks or smells broken down, so I can only assume its good. My trans shifted hard when it was running anyway cause of the solid rear motor mount.
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby Chinky420 » Tue Jul 21, 2009 9:08 am
running RP atf in my gen 1 since i had the tranny replaced about 8k miles ago.
1mz NA with minor bolt-ons
she runs good, smooth shifts, no power surging between gears, no hunting for gears when doing moderate driving through hills.
now, since i had to replace my previous tranny (at something like 130k miles), i don't know if it's a huge improvement, a slight improvement, or the same as the dexmerc that was in there previously....but so far i have not had any complaints about the RP atf.
....and i'm not sure.....but don't the auto trannys hold something like 10+ quarts of atf? i had my mechanic do my tranny work, so i don't know for certain how much fluid it holds.
Chinky420
Postby lexmex » Tue Jul 21, 2009 10:41 am
There's friends with the RX300 who run the RP, Redline and like myself, the Amsoil ATF, and I don't know anyone of them that has had an issue yet with our trannies. We even have a few running M1 ATF and no issues thus far.
lexmex
Postby SleeperSolara » Tue Jul 21, 2009 4:06 pm
I'm runnin' the Royal Purple ATF fluid.
I've also got a external transmission cooler also.
Will be upgradin' the external unit to a bigger one.
