SolaraGuy.com • View topic - Am I the only person whose CEL comes on after each fill up?
Postby Reggy » Tue Jul 21, 2009 11:51 pm
I searched and it seems that way. Ive ever owned a car made after '97 so maybe there's a new fangled way to fill up a tank that I don't know about. I went to my mechanic the first time the CEL light went on and he told me to turn my car off before I put in gas. I didn't think anyone filled up with their engine on so after the CEL was off I drove off. I went to fill up my tank today and when I drove a mile away it came back on. I searched on here and from what I've read with people having the same problem it is bad gas or a cap that's not tight enough. I truthfully don't think it's either of these problems but I maybe wrong. If anyone has any insight would be great.
Reggy
Postby kingkakyle » Wed Jul 22, 2009 12:07 am
list the code here
and also when u close the cap how many times does it click before u stop
maybe u should buy a replacement gas cap
Postby Reggy » Wed Jul 22, 2009 12:18 am
clicks once or twice and ill pass by autozone later and list the code when I come back.
Reggy
Postby Reggy » Wed Jul 22, 2009 7:14 am
nvm got it fixed it was just a bad gas cap
Reggy
Postby yaddadaimsayin » Wed Jul 22, 2009 10:32 am
i don't think it's necessarily bad.. maybe just not tightened enough. My CEL used to come on when I clicked it only once or twice. Now I click it 3-4 times and everything's cool.
Postby Reggy » Wed Jul 22, 2009 2:56 pm
I was wrong, I was driving down I-95 today and the light went back on so i swung by autozone and got these two codes
P1155 A/F Sensor Heater Circuit Malfunction (Bank #2 Sensor #1)
and
P1150 A/F Sensor Circuit Range / Performance Malfunction (Bank #2 Sensor #1)
Sorry, I can get what it says but I have no idea what it means. Can someone help me out here?
Reggy
Postby Reggy » Thu Jul 23, 2009 11:17 am
I was driving around and whenever i was at a red my rpms would hit around 800. From searching around here im guessing its 02 sensors but Im no mechanic so I have no clue.
Reggy
Postby 99BlackSandv6 » Thu Jul 23, 2009 11:27 am
Sorry man, you have a bad O2 sensor. Just replace it and your golden. Bank 2 sensor 1 should be the one you can see when you open the hood. Easy to replace, not real cheap though.
Postby Chinky420 » Thu Jul 23, 2009 2:45 pm
make sure to find out whether you're cali spec or federal spec
cali spec uses a/f meters
fed spec uses oxygen sensors
the a/f meter is much more expensive, while the oxygen sensor is only about 60 bucks.
don't buy bosch, buy denso
and from the looks of the code, i would guess it's a cali spec car (a/f meter)...but you should find out for yourself...i believe you can find out by looking at the sticker on the underside of your hood....where it has the picture for the engine belts.
someone should correct me if this is not where to find out if the car is federal/cali spec.
Chinky420
Postby Reggy » Fri Jul 24, 2009 9:25 am
yep its cali spec, will a o2 sensor not work on it?
Reggy
