SolaraGuy.com • View topic - When I put my car in part sometimes in will roll forward
Postby briang0 » Fri Jul 24, 2009 8:33 pm
My 1999 Solara with 220000 miles on it has started to do this. When I put it in part it will roll either forward or backward depending on the incline. While doing this it will clunk a few times until it catches. I'm wondering if this is something I can fix or will it have to go to the transmission shop.
briang0
Postby kingkakyle » Fri Jul 24, 2009 8:51 pm
do u use ur hand brake?
Postby ThatVietGuy » Fri Jul 24, 2009 9:32 pm
It's supposed to do that...
ThatVietGuy
Postby lilm » Fri Jul 24, 2009 9:41 pm
specify how far it wil roll. It's not supposed to clunk though...
lilm
park
Postby NRDriver » Fri Jul 24, 2009 10:46 pm
it sounds like there is something wrong with your parking pawl. its an internal component
NRDriver
Re: park
Postby youngblood » Sat Jul 25, 2009 9:42 am
NRDriver wrote:it sounds like there is something wrong with your parking pawl. its an internal component
^^^^^x2
I would recommend keeping your foot partially on the brake pedal after shifting to park so that the pawl can slip slowly and gently into place. Assuming it's not a matter of the gear selector being out of adjustment, you are looking at a complete tear-down of the trans to fix the pawl. I'd just try to be gentle and milk it along.
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
Postby solara90 » Sat Jul 25, 2009 3:59 pm
sounds like my old ranger it would roll and go clunk.. use the hand brake
02 solara 2az
solara90
