SolaraGuy.com • View topic - ignition failing
ignition failing
ignition failing
Postby evilkazuya1 » Sat Aug 01, 2009 12:29 am
i had to change my ignition and after i put all the plug bck the car doesnt start the battery its fine i can close windows and moonroof but the car doesnt stare does anyone know what could be the problem
evilkazuya1
Postby ThatVietGuy » Sat Aug 01, 2009 1:29 am
Could be a starter problem.
You might not be getting spark from the plugs.
Does it sound like it wants to crank?
ThatVietGuy
Postby GreenSolara01 » Sat Aug 01, 2009 6:14 pm
what part of the ignition system did you change?
GreenSolara01
Postby youngblood » Sun Aug 02, 2009 5:05 am
We can help but we need more info!
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
Re: ignition failing
Postby evilkazuya1 » Mon Aug 03, 2009 7:22 pm
evilkazuya1 wrote:i had to change my ignition and after i put all the plug bck the car doesnt start the battery its fine i can close windows and moonroof but the car doesnt stare does anyone know what could be the problem
i found the problems its the transponder on the key but thanks
evilkazuya1
Postby evilkazuya1 » Mon Aug 03, 2009 7:24 pm
my cpmputer broke down too so i couldnt log in i was a bad bad week for me but i change trhe transpoinder fron\m the old key to the new one its easy juste opened and swap them
evilkazuya1
Postby GreenSolara01 » Mon Aug 03, 2009 7:25 pm
Good Tip!
GreenSolara01
