SolaraGuy.com • View topic - Window sills faded
Window sills faded
Window sills faded
Postby knightbird123 » Fri Aug 14, 2009 3:16 pm
The rubber window sills on my driver and passenger door are completely faded out. They make the car look like crap.
Is it a difficult job to install new ones?
Can someone help tell me how to install them....
knightbird123
Postby BLACK V6 » Fri Aug 14, 2009 9:10 pm
Nope. Peel back the weatherstripping n there should be some screws behind it. If I remember right, that's all it takes...
BLACK V6
Postby ~SolaRaSpeed~ » Fri Aug 14, 2009 9:41 pm
yeah but the cost on the trim and seals is what gets ya...
~SolaRaSpeed~
Postby knightbird123 » Sat Aug 15, 2009 9:57 am
can i do this job without uninstalling the door panels?
knightbird123
Postby wkbrdr91 » Sat Aug 15, 2009 10:01 am
I had to get all mine replaced on my car about a month after buying it, it didnt take them long at all, but i cant tell you a price cause it was a warranty thing.
2006 Solara Sport
wkbrdr91
Postby ~SolaRaSpeed~ » Sat Aug 15, 2009 9:32 pm
if you're talking about the ones on the door and not on the body of the car then no you can not replace them without removing the panels. but that is pretty easy to do with a screw driver and a little force.
~SolaRaSpeed~
Postby wkbrdr91 » Sat Aug 15, 2009 9:37 pm
oh btw, just a cool thing was when i had mine replaced, toyota initially refused to fix it for some reason, there was a big air leak between the door and window in the corner, and all the trim needed replacing and adjusting. so we disputed like 2 thousand dollars (payed half cash, half credit for car) off the car, and thats when they fixed it, but they never said anything more about it after... so that problem made me two grand :)
2006 Solara Sport
wkbrdr91
Postby knightbird123 » Wed Aug 19, 2009 3:49 pm
where can i get the Gen 1.5 weather strips for the driver and passenger window?..........looked on the net but did not find any
knightbird123
Postby dug320 » Tue Sep 08, 2009 9:01 pm
Simple way to make any molding look and act like brand new.
Silicone. The spray will work but does not last. Silicone grease (Amazon.com) used in electrical and plumbing will rejuvenate the molding and it will LAST.
Wipe it on, rub it in and wipe off extra to use in another spot.
dug320
Postby ~SolaRaSpeed~ » Tue Sep 08, 2009 9:05 pm
i've used silicone spray for quite a while to help rejuevenate the seals but never thought to use the grease. Nice tip!
~SolaRaSpeed~
