SolaraGuy.com • View topic - How do i fix these scratches on my car?
Postby __KINGPIN__ » Mon Aug 17, 2009 11:21 am
also the paint in 1 area of the bumper seems to be chipped a little
__KINGPIN__
Postby Ilovemylara » Mon Aug 17, 2009 11:23 am
If they are only in the clear coat, then you can buff them out. If they are through the color coat as well, then you will have to touch them up using a touchup paint pen. Autozone sells them.
Postby wkbrdr91 » Mon Aug 17, 2009 11:28 am
Toyota has touch up paint, just go up there and they will have this little bottle that will have a "pen" on one side, and a small brush on the other, you can then just paint over these scratches, i personally would also buy some clearcoat from them and put it over that after it dries. let me know how that ends up looking, as i got some pretty bad scratches on my 08 pathfinder the other day. I cant tell how deep yours are, but mine took out all the paint (down to the plastic, which the bumper is made of)
2006 Solara Sport
wkbrdr91
Postby __KINGPIN__ » Tue Aug 18, 2009 4:44 pm
heres a closer look on the scratches
there seems to be a bit of a crack on the bumper paint
and a small part below it. the plastic is totally off
Image Image
Image Image
Image Image
__KINGPIN__
Postby wkbrdr91 » Tue Aug 18, 2009 4:48 pm
I would have it professionally done if your bumper is cracking, that problem is only gonna get worse as time goes on. but if you want a quick and cheap fix, touch up paint is the way to go
2006 Solara Sport
wkbrdr91
