SolaraGuy.com • View topic - Painting the grill (any spraypaint would be good?)
Postby __KINGPIN__ » Mon Aug 17, 2009 3:00 pm
i have a gen 1 solara and i would like to paint the middle part (including the toyota emblem) i was wondering if i can use any black spraypaint or it has to be a specific type?
thanks
__KINGPIN__
Postby yaddadaimsayin » Mon Aug 17, 2009 3:25 pm
you technically can but it may not bond so well to the plastic and may also peel pretty quickly. there are paints that are specifically made for sticking to plastic that will work better. remember to give it a good sand and apply several clear coats as well to ensure a smooth(er) finish.
Postby Toy1mzfe » Mon Aug 17, 2009 3:33 pm
I use duplicolor.
Just sand it down, clean it, then spray.
Postby __KINGPIN__ » Mon Aug 17, 2009 5:48 pm
currently it is stock
Image Image
but i want the middle blacked out
does that mean im going to have to repair the whole grill or just the middle part?
Image Image
__KINGPIN__
Postby 99BlackSandv6 » Mon Aug 17, 2009 10:56 pm
Hmmmm....I think that looks a little off. It's an interesting idea though. I prefer a shiny chrome or gold emblem vs the black. If you want to do that, you can just mask of the rest of the grill and spray the middle. No need to redo the whole thing unless you want to. Have fin with it and post pics when you finish.
Postby k-0tik » Tue Aug 18, 2009 12:41 am
You can use any, just sand it down first so the paint could stick on good.
k-0tik
Postby __KINGPIN__ » Tue Aug 18, 2009 4:41 pm
so i took a closer look at my grill and looks like its chipping and coming off.
i would definitly need to repaint the whole inside of the grill
so i need to sand that part as well?
Image Image
__KINGPIN__
Postby mers714 » Tue Aug 18, 2009 6:45 pm
i painted my whole grill flat black, I left the emblem chrome and i love the way it looks
i just sanded, washed with soap, taped off the emblem, then painted about 3 coats
2000 Solara V6 SE AUTO - TRD RSB - TINT - 6K HID's
mers714
Postby bigmitch » Fri Aug 21, 2009 7:01 pm
I used Krylon Fusion on mine, works real well. It's designed for painting plastics. Even though its not needed I used adhesion promoter prior to spraying and then clear coated it when finished with the black.
bigmitch
Postby needmorecrap » Wed Aug 26, 2009 6:20 pm
Krylon fusion is the best for sticking to plastic.
Sand it down, do a few LIGHT coats, then spray a few light coats of clear coat on it. i did that 2 or 3 years ago and it still looks brand new.
needmorecrap
