SolaraGuy.com • View topic - radiator fans on whenever the ignition is on.
Postby corlon » Tue Aug 18, 2009 12:03 am
whenever i turn my ignition on the radiator fans come on. even at a cold start. i did a search, but couldn't find a solution. does anyone have any ideas or can post a link?
NiCe
corlon
Postby Midias » Tue Aug 18, 2009 6:05 am
Is your ac on?
Postby GreenSolara01 » Tue Aug 18, 2009 6:58 am
Is it hot out?
GreenSolara01
Postby corlon » Tue Aug 18, 2009 8:47 am
no the a/c is not on. no it is not hot out.
NiCe
corlon
Postby indiglosolara » Tue Aug 18, 2009 9:19 am
your sensor for the fans may be bad.. its a relay so it possible that its sticking.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby corlon » Tue Aug 18, 2009 11:55 am
where is the sensor located?
NiCe
corlon
Postby SleeperSolara » Tue Aug 18, 2009 3:15 pm
corlon wrote:where is the sensor located?
There should be a box on the left side of the radiator, check what the underside of the cover says, check the one in front of the battery too.
Picture so show you somewhat where the boxes are.
Postby 99BlackSandv6 » Tue Aug 18, 2009 3:58 pm
If the coolant temp. sensor is bad it may be telling the ecu that the engine is hot, thus turning your fans on all the time. Check the coolant temp. sensor.
Postby corlon » Wed Aug 19, 2009 12:05 am
the temp gauge in the dash reads normally. when its cold reads cold. when hot reads hot. i unplugged the temp sensor on top of the engine by the pcv valve and the check engine light comes on. so i'm guessing thats not the problem.
NiCe
corlon
Postby Midias » Wed Aug 19, 2009 5:11 am
corlon wrote:the temp gauge in the dash reads normally. when its cold reads cold. when hot reads hot. i unplugged the temp sensor on top of the engine by the pcv valve and the check engine light comes on. so i'm guessing thats not the problem.
Probably 2 sensors most cars have a fan temp switch and a gauge temp switch.
Re: radiator fans on whenever the ignition is on.
Postby corlon » Sat Sep 18, 2010 10:18 pm
bump.
getting cold out again and still have the same problem. anyone else encounter this issue yet?
NiCe
corlon
Postby Midias » Sat Sep 18, 2010 11:06 pm
Did you check the temp switch on the bottom of the radiator as I suggested on aug19 2009?
Looks like this
Postby corlon » Sat Sep 18, 2010 11:14 pm
yeah. i've gone throuugh the toyota manual and tested the sensors and relays. i think 3 different sensors can trigger the fans. everything tested normal or i'm overlooking something. the only way to shut them off while the ignition is on is to remove a relay.
NiCe
corlon
Postby Midias » Sat Sep 18, 2010 11:17 pm
corlon wrote:yeah. i've gone throuugh the toyota manual and tested the sensors and relays. i think 3 different sensors can trigger the fans. everything tested normal or i'm overlooking something. the only way to shut them off while the ignition is on is to remove a relay.
is the relay stuck?
Postby solara90 » Mon Sep 20, 2010 3:58 pm
if you said you checked the sensor, and relays. according to the wiring diagram theres a coolant temp sensor, and water temp switches 1 & 2. I dont have a V6 so i cant really help too much.. but also check for shorts
02 solara 2az
solara90
