SolaraGuy.com • View topic - fuse location
fuse location
fuse location
Postby 5sfe » Sun Aug 23, 2009 4:23 pm
were is the fuse that controls the power window because my driver side window stop working.
5sfe
Postby ThatVietGuy » Sun Aug 23, 2009 4:30 pm
Behind the coin tray down and to the left of the steering wheel.
ThatVietGuy
Postby solara90 » Sun Aug 23, 2009 6:09 pm
you have no idea how it took me to find that
ThatVietGuy wrote:Behind the coin tray down and to the left of the steering wheel.
02 solara 2az
solara90
Postby 5sfe » Sun Aug 23, 2009 7:49 pm
i know, but i couldn't find that certain fuse... out of nowhere it started to work again, idk how, well now my automatic headlights nor my daytime running lights are working, i have to turn them on manualy, could be a fuse?
5sfe
Postby D-money » Sun Aug 23, 2009 7:53 pm
sounds like your fuse box connections are loose check the wires on the back make sure they are plugged in all the way
D-money
Postby GreenSolara01 » Mon Aug 24, 2009 7:34 pm
I owuld look at the harnes under the switch as well
(you might also want to check the window lock switch)
GreenSolara01
Postby 5sfe » Tue Aug 25, 2009 9:57 am
why would i check my window lock switch??... i was trying to put a radio but failed, so i put the old one back on, you think something back there got lose?
5sfe
Postby GreenSolara01 » Tue Aug 25, 2009 10:01 am
JUst saying if it was a window problem, I would check the switch if the fuse was ok. Deff if it wasn't working and started working again. Sounds like a lose contact.
GreenSolara01
Postby 5sfe » Tue Aug 25, 2009 10:37 am
GreenSolara01 wrote:JUst saying if it was a window problem, I would check the switch if the fuse was ok. Deff if it wasn't working and started working again. Sounds like a lose contact.
i was trying to say why would i check the switch i'm not saying your opinion was wrong. i jsut wanna know why is their a fuse or something...i guess i have to take off the radio and relook what i did and check the cables.. any feedback is welcome
5sfe
Postby GreenSolara01 » Tue Aug 25, 2009 4:42 pm
Did you insatll the aftermarket radio?
do you know if you had to jump an acc circut to the radio? you know one that is on when the key is in and on. its just a shot in the dark, good luck
GreenSolara01
Postby 5sfe » Wed Aug 26, 2009 11:40 am
well now things are working, but today my window stop working again, i don't know whats going on with my window
5sfe
Postby Pogs » Wed Aug 26, 2009 11:53 am
sounds like a loose connection somewhere... that or lara is playing tricks on you
Search and Win
Pogs
Postby 5sfe » Thu Aug 27, 2009 5:37 pm
theirs power to the switches, but no movement
5sfe
Postby GreenSolara01 » Thu Aug 27, 2009 5:53 pm
I would make sure you have power to the motor or at least check for continuity.
GreenSolara01
Postby 5sfe » Sat Aug 29, 2009 7:34 pm
well now i know it goes up but not down, what could cause this
5sfe
