SolaraGuy.com • View topic - (HELP) uninstalling headlights and corners on Gen 1.5
Postby knightbird123 » Wed Aug 26, 2009 5:25 am
How in the world do you take the stock headlights and corners out of a Gen 1.5? They are so compact in there, do i remove the corners 1st then remove the headlights, I already unscrewed everything.
Is there a pattern to getting the corner out, like push forward and out or....?
This is much worse than working on a camry.
This job is so difficult
knightbird123
Postby knightbird123 » Wed Aug 26, 2009 5:55 am
Toyota Camrys r much better engineered than the Solara
knightbird123
Postby akora12 » Wed Aug 26, 2009 5:59 am
The corners come out first. Sometimes they can be wedged in there, so get a taped screwdriver or something to help pry them from the back. Once the corners are out, you can access the last two nuts holding the headlights in.
