SolaraGuy.com • View topic - HELP!! 2000 V6, 5Sp. Pulls a no start
Postby platypusfetch » Mon Aug 31, 2009 7:56 am
So. I go for gas. car works fine. Gas up. Pay. come out and Car will not start. Car is bone stock 2000 V6 5speed. 110000 KM on the ODO.
Started to trouble shoot stuff.
I have Lots of Battery. (car at rest batt says 12.6V)
I can bump start the car ( pushing in second and dump the clutch and she runs like a champ)>
I have no power going to the starter while attempting to crank it over (trouble light tested)
C'mon fellas!! help a guy out.. car is in a shop and the labor clock is running and they have no idea!!!!!!!
Thanks< Platy
platypusfetch
Postby Jakecallun20 » Mon Aug 31, 2009 11:03 am
Ignition Switch?
Postby 99BlackSandv6 » Mon Aug 31, 2009 11:54 am
Starter relay?
Re: HELP!! 2000 V6, 5Sp. Pulls a no start
Postby jimmm » Mon Aug 31, 2009 12:18 pm
platypusfetch wrote:C'mon fellas!! help a guy out.. car is in a shop and the labor clock is running and they have no idea!!!!!!!
Thanks< Platy
Is that how they do it in Canada? Charge for no ideas? jimmm
jimmm
Postby Inverted » Mon Aug 31, 2009 12:28 pm
jimmm wrote:Is that how they do it in Canada? Charge for no ideas? jimmm
Pretty much!!
Inverted
Postby 99BlackSandv6 » Mon Aug 31, 2009 12:32 pm
Take it out of that shop, if they have no idea it doesn't need to be there. It's gotta be something simple if you can bump start it but not crank start it. Don't pay incompetent people to do a job that they aren't qualified to do.
Postby akora12 » Mon Aug 31, 2009 12:49 pm
What the hell, I've never heard of a shop charging for a car just sitting in their shop...especially when they can't even fix it.
Postby JamesT » Mon Aug 31, 2009 1:08 pm
Does it give you any issues when it's running normally?
BespokeAutoInterior
JamesT
Shift Boot Master Crafter
Postby Eye8Pussies » Mon Aug 31, 2009 1:52 pm
check your neutral safety switch- on a 5-speed, the starter won't turn without it being activated (by the clutch)
Postby 5sfe » Mon Aug 31, 2009 6:25 pm
if the car has an alarm, this means the killswitch is active, and it didn't deactive when you disarmed the car, so what you can do is disconnect the alarm, get a good thick small cable, an where you see two thick red cables, where the alarm connects, you take the cable and make it direct, then you can start the car, because from what i hear is that your starter isn't recieveing a signal from the switch to the starter, this what the killswitch does, cancel's the signal.
5sfe
Postby imhappy » Tue Sep 01, 2009 9:09 pm
fuel pump ... fuel pressure regulator... clogged fuel filter
imhappy
Postby imhappy » Tue Sep 01, 2009 9:10 pm
ooops didnt read that last sentence.... starter problem... tap it with something metal.
imhappy
Postby corlon » Wed Sep 02, 2009 8:48 pm
i like the idea of checking the circuit on the clutch switch.
NiCe
corlon
Postby 99BlackSandv6 » Wed Sep 02, 2009 8:53 pm
imhappy wrote:ooops didnt read that last sentence.... starter problem... tap it with something metal.
STOP! Don't hit your starter with anything, it contains permanent magnet that can be broken if the starter experiences an impact. That method was only safe on the old starters with stator windings. Also if the starter isn't getting power, that wouldn't be the first problem. You have to figure out why the starter isn't getting power.
Postby ozone » Tue Sep 08, 2009 9:41 pm
Try the ground wire on the battery. Even if it seems good, try a new one or an additional one. I had one that looked good with a multimeter, but it was not good enough to start the truck. So don't just look for continuity on the ground, really get a good connection.
This isn't rocket science. There are only three connections to the starter. Two of them are dead simple. They are: battery, ground and start signal. The power comes directly from the battery, the ground is through the chassis of the starter being bolted to the block, and the starter signal goes through the following path:
Battery>fusible link block>40A main fuse>starter relay>starter. The following components may effect those things:
Ignition switch, 5A starter fuse, clutch starter switch or neutral position switch, and a couple of junction connections (J7 and J26).
Good luck.
ozone
