SolaraGuy.com • View topic - Installing Hyper Voltage Stabilizer
Postby x99suplarax » Mon Aug 31, 2009 10:08 pm
How do i install it? Connect it to the positive&negative terminal or the positive terminal &' ground..The metal piece on the car...
Help please? ( sorry cant explain clearly )
x99suplarax
Postby Ilovemylara » Mon Aug 31, 2009 10:14 pm
Positive from the stabilizer should definatly go to the positive battery terminal, and ground would go to the ground on the battery. Or perhaps if you want a better ground, you could run it to a strut tower bolt
Postby 99BlackSandv6 » Mon Aug 31, 2009 10:35 pm
What is this supposed to do?
Postby Ilovemylara » Mon Aug 31, 2009 10:39 pm
Its basically a capacitor in a fancy box... It holds an extra charge and helps to eliminate voltage drop when the electrical system is under load. Especially when your subs hit. Not really any HP gain.
