SolaraGuy.com • View topic - Is this normal mileage for a 99 solara v6
Postby __KINGPIN__ » Tue Sep 01, 2009 8:22 pm
half tank 176907 miles
empty tank (when the light comes on) 176990
__KINGPIN__
Postby LEE337 » Tue Sep 01, 2009 8:25 pm
83 miles on a half a tank???
No thats not normal.
Postby jetbtkng » Tue Sep 01, 2009 8:37 pm
176907 miles on a half a tank, thats good, i only get 16,469 on a half tank............................... :drinking:
Postby 1gSE » Tue Sep 01, 2009 8:38 pm
does it run and idle like sh*t and smell like fuel?
Solara-M62 @ 5.5psi
1gSE
Postby ChrissyD123 » Tue Sep 01, 2009 8:47 pm
LEE337 wrote:83 miles on a half a tank???
Agreed. That sounds horrible
</SolaraGirl>
{15inch JL sub w/ 1000 JL Watt Amp.... Stock engine, but clean Lara}
ChrissyD123
Postby imhappy » Tue Sep 01, 2009 9:07 pm
no its not.....
imhappy
Postby 99BlackSandv6 » Tue Sep 01, 2009 9:23 pm
It should be more like 200mi.
Postby __KINGPIN__ » Tue Sep 01, 2009 9:26 pm
1gSE wrote:does it run and idle like sh*t and smell like fuel?
yes it does.
what should i do to get this fixed?
or is it even worth fixing
__KINGPIN__
Postby Dawgz » Tue Sep 01, 2009 9:40 pm
Do u have a CEL? If so go get it read, maybe the ECU is dumping more fuel for a reason.
Postby __KINGPIN__ » Tue Sep 01, 2009 9:43 pm
the engine light is on.
what is ecu?
__KINGPIN__
Postby Dawgz » Tue Sep 01, 2009 9:48 pm
__KINGPIN__ wrote:the engine light is on.
what is ecu?
Go get the CEL read by autozone or similar store if you dont have access to an OBDII Scanner.
ur ecu takes care of the fuel trim, etc. Its the brain of the car, essentially (mini computer).
The problem may be that one of your [o2 / (A/F if your cali spec)] sensors needs to be replaced....or possibly blew a knock sensor (do u feel any power loss after 3k rpms?).
Postby Dawgz » Tue Sep 01, 2009 9:53 pm
damn, did the math real quick, and ur getting like ~9mpg...
Postby __KINGPIN__ » Tue Sep 01, 2009 9:55 pm
how much would it cost to get it replaced? i havnt really paid too much attention to any power loss/etc after. 3k. but i will try it out
__KINGPIN__
Postby GreenSolara01 » Tue Sep 01, 2009 10:07 pm
Thats got to be the worst mpg I've seen posted in here! Your car is not injecting gas its got a team of midgits dumping buckects of gas into your engine, or possibly on the ground.
ECUs are not cheap, but you might get lucky and find a salvage one.
Good Luck
GreenSolara01
Postby Dawgz » Tue Sep 01, 2009 10:08 pm
ur ecu shouldnt be at fault here...there is an issue elsewhere (thats the reason ur CEL is on).
Just go get it read and post up what codes you are getting from the CEL.
