SolaraGuy.com • View topic - Transmission fluid change revisited
Postby bigmitch » Sun Sep 06, 2009 6:56 pm
Just got done doing a search and couldn't find an answer to my question. I plan on doing trannie fluid change on sons lara. I also plan on changing the filter (strainer) but question I have is should I wait until the final fluid change (2nd time around) or do it on the initial drain. Thanks in advance for any help and info you could provide.
bigmitch
Re: Transmission fluid change revisited
Postby Dawgz » Sun Sep 06, 2009 6:58 pm
bigmitch wrote:Just got done doing a search and couldn't find an answer to my question. I plan on doing trannie fluid change on sons lara. I also plan on changing the filter (strainer) but question I have is should I wait until the final fluid change (2nd time around) or do it on the initial drain. Thanks in advance for any help and info you could provide.
U could do it the first time around.
When u drain the fluid, u can also figure out then if u want to wait till the second or third time around if the fluid isnt red/pink.
Postby GreenSolara01 » Mon Sep 07, 2009 5:33 pm
Don't forget the Diff, it shares same pool but doesn't come out when you drain the tranny.
GreenSolara01
