SolaraGuy.com • View topic - taillights not functioning
Postby knightbird123 » Tue Sep 08, 2009 5:58 pm
All the bulbs in my taillights r new however the taillights are not functioning........any idea what it might be?
my rear signal changers work fine. I also have that amber warning with the little car on my dash.
knightbird123
Postby solara90 » Tue Sep 08, 2009 6:21 pm
check your fuses
02 solara 2az
solara90
Postby lilm » Tue Sep 08, 2009 6:26 pm
fuses
lilm
Postby knightbird123 » Tue Sep 08, 2009 6:34 pm
where is the fuse to the tails located and what do I check for?
I had installed new aftermarket bright bulbs, could it be that they take too much power or something.....causing the fuse to blow out.
I noticed my parking lights dont work either
knightbird123
Postby SleeperSolara » Tue Sep 08, 2009 8:17 pm
There should be a coin thingy near the steerin' wheel.
Pull that out, and there's a diagram on the back.
Postby GreenSolara01 » Tue Sep 08, 2009 8:53 pm
^ if taht doesn't work check the haz button. I was working on my stereo and for got to plug it back in and lights and signals did't work.
GreenSolara01
Postby Inverted » Wed Sep 09, 2009 5:25 am
GreenSolara01 wrote:^ if taht doesn't work check the haz button. I was working on my stereo and for got to plug it back in and lights and signals did't work.
x2
Inverted
Postby knightbird123 » Wed Sep 09, 2009 5:50 am
I put in a 30A to replace the 10A tail fuse shown on the diagram sticker from the coin holder. Smoke and a burning smell started to fill up the inside of my car. I though my car was going to light on fire.
Maybe I have a short somewhere, I dont know.........my headlights/fogs work fine but the parking and tails wont work. All turn signals and hazards work.
I took out these aftermarket blue super white bulbs and put back my original stock taillight bulbs. I was assuming those bulbs took up too much power.
I have no idea as to why my tails wont go on. It keeps blowing the 10 amp fuse.
knightbird123
Postby makethemusic72 » Wed Sep 09, 2009 7:04 am
its not the fuses if it keeps blowing the same fuse, and don't try and put a different amperage fuse in. thats bad. how new are your bulbs?
2003 Solara 4 Cyl, automatic. Floss as @#$%.
makethemusic72
Postby fctoyota » Wed Sep 09, 2009 7:47 am
check the lamp failure sensor, its in the back on the left iin back of the trunk carpet
fctoyota
Postby solara90 » Wed Sep 09, 2009 8:09 am
never replace a fuse with a higher amp one. The wires are only designed to carry a certain amount safely
02 solara 2az
solara90
Postby knightbird123 » Wed Sep 09, 2009 11:06 am
Well I took my car to the mechanic and they said the front left parking light socket was bad. They said something about the terminals/two wires touching. They said if the problem happens again then I would have to replace the socket. Im confused on which socket they mean....... not sure if this is the car or the aftermarket headlights were faulted.
My car has the Black Diamond aftermarket head/corner lights
http://cgi.ebay.com/ebaymotors/02-03-TO ... ccessories
knightbird123
Postby Chinky420 » Fri Sep 11, 2009 4:12 pm
lol, your JDM parts didn't jive well with our domestically made cars.
sounds like you melted your own sockets by installing a bigger fuse with stronger bulbs.
this is why you do not overload a circuit by taking out the safety (the fuse, which you basically made useless by installing a 30A instead of the appropriate 10A)
stick to OEM amperage bulbs, and buy yourself a new socket.
if you're lucky, you just fried your sockets, instead of frying all your wiring.
btw, i was joking about the headlights, i'm pretty sure the issue is with the bigger bulbs and the bigger amp fuse.
Chinky420
