SolaraGuy.com • View topic - compression test
compression test
compression test
Postby 5sfe » Fri Sep 11, 2009 2:00 pm
i'm going to do a compression test at my house with my friend whats the rating on the engine...is it 125,110, 90 around their?
5sfe
Postby 5sfe » Fri Sep 11, 2009 4:06 pm
well i did my test and the result was 150 on all four, which is bad.. now i put oil in the chamber in it jump to 200 on all four, which means?
5sfe
Postby lilm » Fri Sep 11, 2009 4:14 pm
142 minimum with 178 maximum on the 4 cylinder
EDIT:
if compression increases after the oil is added, the piston rings are definitely worn
lilm
Postby 5sfe » Fri Sep 11, 2009 4:22 pm
so 150 is good right? now if 178 is maximum then 200 is over doing it and if 200 stays, i would need to use higher grade of fuel right?
5sfe
Postby Ilovemylara » Fri Sep 11, 2009 6:20 pm
That oil wont stay in the cylinder for long, and your compression will drop back down to 150.
Postby 5sfe » Sat Sep 12, 2009 7:33 am
so my pistons are fine, if they are pumping 150psi in each cylinder and the minimum is 142, hmm how can i increase the compression, some say i need head work, do my intake and exhaust ports, and do the pistons, they said also that just doing the intake ports and exhaust will be fine.... if this is true then its going to be cheap increase in horsepower
5sfe
