SolaraGuy.com • View topic - Radiator leak...need help!
Postby solara1989 » Tue Sep 15, 2009 7:41 am
Hello everyone, i need some suggestions, i have a leak "hole" in the radiator, its been leakin for some time now, so im planin in buyin a new one. my question is, should i buy a new one from the dealer or is there an aftermarket high performance radiator superior to the OEM? thanx for your help.
2000 Solara SLE V6 Diamond White
solara1989
Postby SleeperSolara » Tue Sep 15, 2009 8:44 am
Check out CSF radiators.
Postby kenny6683 » Tue Sep 15, 2009 10:45 am
the radiator or the hose?? because usually you just get leaks from the hose
kenny6683
Postby Ruski » Tue Sep 15, 2009 10:48 am
wheres the hole, do not spend the money on a dealer radiator, but get a decent replacement not some ebay crap
Postby solara90 » Tue Sep 15, 2009 10:49 am
use a egg :-)
but im with everyone else dont get a dealer one, and dont get a crappy ebay
02 solara 2az
solara90
Postby Ilovemylara » Tue Sep 15, 2009 11:06 am
aluminum radiators work so much better than oem ones. Try to find a good aftermarket alluminum one.
Postby imhappy » Tue Sep 15, 2009 11:11 am
i would recommend a aluminum one also.... 4 rows
imhappy
Postby SleeperSolara » Tue Sep 15, 2009 11:25 am
imhappy wrote:i would recommend a aluminum one also.... 4 rows
If you can find a 4 row radiator for the V6, mad props, cause i've been lookin' foreva for one....
Postby Ilovemylara » Tue Sep 15, 2009 11:27 am
http://cgi.ebay.com/ebaymotors/04-05-TO ... ccessories this is for the 3.3 liter 3mz-fe, but the dimensions are the same as a 3.0 one, so I bet it would fit.
