SolaraGuy.com • View topic - Weird Solara 00 issue
Postby thatdamngoodcire777 » Wed Sep 16, 2009 12:21 pm
Hey everyone. My car still runs good but im having an issue I cant figure out. My check engine light goes on sometimes and then shuts off. The engine also sounds a little louder then usual. The engine also idles high and takes a while to go back down. And you can hear the engine struggling when the air is turn on and off in the car. I replaced the air filter, seafoamed the gas tank and engine and filled up all of the fluids. I had a tune up about 20K-30K miles ago and the transmission fluid changed at about the same time. Anybody have any ideas? Thanks a lot!
thatdamngoodcire777
Postby ThatVietGuy » Wed Sep 16, 2009 1:24 pm
Have you tried going to an Autozone to check the code?
ThatVietGuy
Postby Chinky420 » Thu Sep 17, 2009 1:54 pm
1. goto autozone and have them read the code
2. ????????
3. profit
Chinky420
Postby solara90 » Thu Sep 17, 2009 2:42 pm
sounds like it could be your IAC
02 solara 2az
solara90
Postby 99BlackSandv6 » Thu Sep 17, 2009 2:53 pm
X2 on IAC. Since you said the car seems to struggle when the AC is on, that leads me to suspect that the IAC valve is stuck, and or clogged, and the engine is unable to idle up to compensate for the extra load caused by the AC compressor. I don't think that would throw a CEL though, but it might. Also a stuck IAC valve would explain why the idle runs high and takes a while to settle down. I'm not sure what might be causing the car to be louder, I figure it's unrelated.
Postby ~SolaRaSpeed~ » Thu Sep 17, 2009 5:38 pm
give us a CEL code and we might be able to give you a better idea.
~SolaRaSpeed~
Postby JamesT » Thu Sep 17, 2009 6:11 pm
Exhaust or EGR leak maybe?
BespokeAutoInterior
JamesT
Shift Boot Master Crafter
Postby NeFaRiOuS_SLE » Fri Sep 18, 2009 6:23 pm
ThatVietGuy wrote:Have you tried going to an Autozone to check the code?
Since I know you're in SoCal, you DO know that we "allegedly" signed a stupid law into place that prevents you from being loaned a scan tool, right? I never heard of the law but it pissed me the fxck off when I got a CEL problem.
Postby Skew » Sat Sep 19, 2009 8:54 am
Gas cap?
Skew
Postby thatdamngoodcire777 » Sat Sep 19, 2009 9:06 am
I checked the exhaust and I'm not sure about an EGR leak. I have had problems with the AC for a long time now. It makes a big pop when I switch where the air is vented in my car. The AC could be clogged. I'll need to check into both issues. But, first stop, Autozone! (luckily, I live in RI, not Cali, so it shouldn't be a problem)
thatdamngoodcire777
