SolaraGuy.com • View topic - 2002 2.4l 4cyl LOW IDLE .... Please help me!
Postby VidGameKing » Wed Sep 23, 2009 11:05 am
I know, I know, the general rule of thumb is to clean the Mass Air Flow Sensor, and clean out the trottle intake... Done, did that! Even replaced the air filter!
I've hooked up my car to a ODB-II reader, the car idles at 650-ish RPM, somtimes it will go as low as 600RPM, when I kick in the A/C it jumps to 780RPM, but then settles back down to 650-ish RPM. When the car is in drive it stays pretty solid at 600RPM.
I want my car to idle at 800-ish to 1000-ish RPM, that seems to be the smoothest idle speed.
How can I program my ECU to tell my blinking car to blinking stay at that blinking RPM range?
Or, what else could be the problem, and how can I fix it? The last thing I want to do is go to a Toyota dealer, I'm affraid of getting charged out the A$$, and I don't trust service station technicians with my car...
He's not any kind of program, Sark. He's a user!
VidGameKing
Postby krawzyazn » Wed Sep 23, 2009 11:19 am
clean your injectors and throttle body
Postby gnegroni » Wed Sep 23, 2009 11:40 am
Dunno man...I guess our cars like to idle that low. Its not as bad as when you disconnect battery and reset ECU (sits lower for a bit).
I too had cleaned everything, TB, sensor, air filter, manifold (SeaFoamed previously), injectors, tank and new spark plugs...and my 2005 2.4L still likes to idle low.
I think 800rpm would be wonderful since its so quiet and vibrations lower a bit, but I guess the stock ECU will always do that.
Somebody, PROVE us WRONG!
gnegroni
Postby VidGameKing » Wed Sep 23, 2009 12:29 pm
krawzyazn wrote:clean your injectors and throttle body
:roll: Yeah, like I said, I did that. After doing a lot of searching here on these forums I came to that conclusion.
But after having done that, it's still right where it's ALWAYS been.
Actually It's like the whole procedure was a waste of my time! The car, since i've had it (I got it in 2007 w/ 32K on it) has idled there. I've seen ZERO improvemnet.
What else could be wrong with my car? Do I need a new MAF sensor? A Throttle Assembly? A new ECU?
VidGameKing
Postby solara90 » Wed Sep 23, 2009 2:49 pm
I'm in the same boat as you. Idles low changed spark plugs, pcv, cleaned tb, injectors, maf
i guess its just a 2AZ thing...
02 solara 2az
solara90
Postby gnegroni » Wed Sep 23, 2009 3:20 pm
solara90 wrote:i guess its just a 2AZ thing...
I guess that sums it up...don't think the cost of a piggyback would we worth idling change (if it could).
gnegroni
Postby VidGameKing » Wed Sep 23, 2009 5:56 pm
gnegroni wrote:I guess that sums it up...don't think the cost of a piggyback would we worth idling change (if it could).
What's a piggyback?
VidGameKing
Postby gnegroni » Wed Sep 23, 2009 6:06 pm
What's a piggyback?
Like a piggyback or standalone ECU...another computer to control engine functions.
gnegroni
Postby VidGameKing » Wed Sep 23, 2009 6:31 pm
How much would one of those set one back?
If it's less than $500 I would buy it to fix my problem.
Don't the Scion TCs use this engine? do they idle low too? Could i use an ECU from one of those cars?
VidGameKing
Postby krook » Wed Sep 23, 2009 7:58 pm
VidGameKing wrote:How much would one of those set one back?
I'm assuming that the ECU/piggyback computer gnegroni is referring to is something like an Apexi S-AFCII or the like....
it shouldn't cost more than 3 bills, but then you'd have to fine someone reputable to tune it (which may cost 50-100 bucks)
check the idler adjustment screw near the throttle--you can adjust the idle from there, i think.
krook
Postby VidGameKing » Wed Sep 23, 2009 8:05 pm
krook wrote:check the idler adjustment screw near the throttle--you can adjust the idle from there, i think.
Yeah, the '02 and newer solara have "drive-by-wire" on the 4cyl engines, it's all computer controlled... no manual adujstment anywhere!
VidGameKing
Postby 5sfe » Wed Sep 23, 2009 8:27 pm
have you talked to toyota?, you didnt say what happend when you connected to the obd2 i will assume nothing, more likely toyota will have an answer for you, and it might not be free.
5sfe
Postby kingkakyle » Thu Sep 24, 2009 2:12 am
weird
my 2az idles around 700-800
Postby gnegroni » Thu Sep 24, 2009 8:02 am
kingkakyle wrote:weird
All in due time, my little grasshoppa!
gnegroni
Postby (K) » Thu Sep 24, 2009 3:08 pm
How many miles are on your cars/engines?
I'm at 108,000 and I'm idling fine @800.
(K)
