SolaraGuy.com • View topic - Check engine light came on and gone
Postby jaynine999 » Mon Sep 28, 2009 1:22 pm
I have 01 solara (with about 170,000 miles) and it's been running great. The check engine came on about 2 weeks ago and I happened to leave the car parked for about a week. It wasn't too strange when I found out that the battery had died and had to jump it. Oddly, now the engine light is gone. Can anyone tell me if this mean that the engine problem has been fixed? I hope it is...
jaynine999
Postby Eye8Pussies » Mon Sep 28, 2009 1:29 pm
nope...it means that your battery went so dead that your ecu had its memory wiped
but chances are that the code will come back. once it does, get it scanned and let us know what it is so we can help you with it
Postby Chinky420 » Tue Sep 29, 2009 2:17 pm
^^ x2
alternatively, it could be said "in order to clear a CEL, disconnect your battery for about 10 minutes"
if it comes back get it scanned
if it doesn't, then i guess problem solved....
Chinky420
Postby Pogs » Wed Sep 30, 2009 7:02 am
if the code came on because say... your gas cap wasnt sealed all the way you would get a code. you would then need to reset battery and it will go away.
If it pops up again it is most likely more serious then "just reset the battery"
Search and Win
Pogs
Postby imhappy » Wed Sep 30, 2009 5:34 pm
if something is still wrong it will show up in a week
imhappy
