SolaraGuy.com • View topic - battery is being drained by an unknown source??
Postby TxBmbleBee » Thu Oct 01, 2009 5:24 pm
I think my wiring is messed up...possibly when the rats were calling my solara home. This isnt the first time this has happened either, but my car has only been sitting for 4 days, and I went to try to start the car and the battery was severely drained. It wasnt even making any clicking noises. Im terrible with wiring, can anyone give me a solid place to start?
oh yea and i used to have an alarm that has since been taken out. but i cant see from that what would be draining my battery?
"i just wanna go fast..."
TxBmbleBee
Postby Ilovemylara » Thu Oct 01, 2009 5:27 pm
could be a bad battery, the car was sitting for a long time, while you were doing the swap.
Postby TxBmbleBee » Thu Oct 01, 2009 5:35 pm
see normally thats what I would think too. but i had that damn battery on a trickle charger lol. and right when i threw it on the car it was fine. however when it was sitting hooked up to the car is when all the life seemed to be sucked out of it.
TxBmbleBee
Postby Ilovemylara » Thu Oct 01, 2009 5:53 pm
wow, thats strange. I guess you could get a multimeter and start checking connections.
Postby wkbrdr91 » Thu Oct 01, 2009 6:05 pm
How long does everyone's battery while listening to music with car off?? I have 2 12's and mine lasts for about 45 minutes (ALMOST found this out the hard way, the car just BARELY started up).
This dosent seem normal to me because at my summer house theres a drive-in we go to, and the battery has never died (in the wrangler, and yukon) with the air conditioning fans going, and radio for 2 full movies.
2006 Solara Sport
wkbrdr91
Postby TxBmbleBee » Thu Oct 01, 2009 6:19 pm
i agree yal, something funky is going on
TxBmbleBee
Postby gnegroni » Thu Oct 01, 2009 7:10 pm
You know, our stock Toyota batteries seem OK, until it suddenly dies. Mine was perfect then one day it couldn't turn the car on, without showing previous hints.
gnegroni
Postby turboman412 » Thu Oct 01, 2009 7:18 pm
start pulling fuses. if your battery is dieing somthing is staying on. you can do a drain test. ( using the neg cable, hook your volt meter up in series i beleave its milli amps. the number is normally about 700 milli amps with nothing but the computer on. key in off position of course
turboman412
Postby Ilovemylara » Thu Oct 01, 2009 8:29 pm
wkbrdr91 wrote:How long does everyone's battery while listening to music with car off?? I have 2 12's and mine lasts for about 45 minutes (ALMOST found this out the hard way, the car just BARELY started up).
I can wash and wax my car with the music on the whole time, (probably about 3 to 3 and a half hours) and although it turns over a little bit "slower" it will start right back up.
Postby TxBmbleBee » Thu Oct 01, 2009 9:01 pm
dang what could be draining it????!? i hate wiring errrr, give me a wrench and some bolts instead
TxBmbleBee
Postby Gibson99 » Fri Oct 02, 2009 10:12 am
isn't that the original battery craig? if so then it's probaly just time... around here we're lucky to get 5 years out of a battery. the AGM battery in my miata lasted almost 8 years, but that's for 2 reasons: it's in the trunk, and it's AGM. trickle charger will keep it topped off, but doesn't guarantee it will HOLD a charge very long.
think of it like a bucket with a pinhole in it. you can fill it to the top w/ a garden hose, but if you let it sit long enough, it will eventually empty. top it off with a drive (run hose for a few mins) and it fills back up.
same thing with the battery. once they start dying, they just don't hold a charge. and yes it happens suddenly.
Gibson99
Postby TxBmbleBee » Fri Oct 02, 2009 7:13 pm
this battery is not even a year old though
TxBmbleBee
Postby Gibson99 » Fri Oct 02, 2009 9:23 pm
ok then it should be under warranty. :) but before you do that, take off the negative cable, then hook up a multimeter between the cable and the battery post and put the meter on amps. you should be at or below 0.5 amps. maybe even less considering everything inside your car is stock. if it's nice and low like that, then just go exchange the battery.
i've seen defective radios draw tons of power and kill batteries.
Gibson99
Postby gnegroni » Sat Oct 03, 2009 2:43 am
I tell you, these Toyota batteries suck...
gnegroni
Postby TxBmbleBee » Sat Oct 03, 2009 2:40 pm
i got the battery from wal mart and yes it is still under warranty. what if its not nice and low jason?
TxBmbleBee
