SolaraGuy.com • View topic - replace struts? springs?
Postby krook » Fri Oct 02, 2009 3:15 am
how do you know when to change your struts/springs? i keep hearing a scraping noise when i drive over dips. i think my wheels are actually rubbing the inside of the fender well as i'm driving!
are my struts or springs bad? i did notice that the gap between the wheel and the fender well was pretty close--more so than usual.
i have Tein springs on Tokiko struts. i put them on about 70,000 miles ago.
krook
Postby Mr_Krispy1183 » Fri Oct 02, 2009 1:33 pm
If anything, it would be the struts. However, double check to make sure it's the front or rear that scrubbing. If it's just the front, taking a heat gun to the fender liner trim and pushing it up may help give you more clearance.
Postby imhappy » Fri Oct 02, 2009 1:46 pm
does ur car bounce up and down if u push it down??? change the struts most likely
imhappy
Postby MiistahSaan » Fri Oct 02, 2009 3:35 pm
imhappy wrote:does ur car bounce up and down if u push it down??? change the struts most likely
MY car bounces up and down alot when i go over like 70mph, is that struts springs or shocks?
MiistahSaan
Postby sarki » Fri Oct 02, 2009 8:27 pm
^^Change your struts. Also check your front tires and see if there cupped. Thats an indicator that your struts are junk.
Who wants to buy it?
sarki
Postby MiistahSaan » Sat Oct 03, 2009 4:32 am
what kind should i get. the one for the front? or the one for the trunk. or under the car? i dunno. but i dont really wanna cut a hole in the trunk lol
MiistahSaan
Postby djandrey_M » Sat Oct 03, 2009 12:57 pm
Use "search" function friend.
djandrey_M
