SolaraGuy.com • View topic - Real Quick- Door Panel Removal
Postby tresola » Sat Oct 17, 2009 1:33 pm
We're trying to remove the driver side door panel to install the new mirror, but it won't come off! we've removed 6 screws already but its like the door handle or something, is holding it up. Help!
tresola
Postby philosophicaljt » Sat Oct 17, 2009 1:40 pm
Probably clips?
2004 Solara SLE V6
Search
philosophicaljt
Postby NVDIS1 » Sat Oct 17, 2009 5:49 pm
did u remove the window switch? there is a another screw that screws to the door that has to be removed once you pull out the window switch and the bezel around the door handle must come off as well.
this should help ya:
http://rayrayonline.bravehost.com/frontspeaker1.htm
Postby bassthrive » Sat Oct 17, 2009 9:25 pm
you must remove the door handle cups, a huge pain in the ass...
there are two hidden upper and lower clips holding it in, i recommend the small screwdriver you use for adjusting sunglasses.
but i dont think you need to remove the whole door panel to access the mirror, just pull off the plastic "sail" piece
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby tresola » Thu Oct 22, 2009 11:34 am
Thanks, we did get it eventually! The clips holding in the door handle were bent, and it took us awhile to get those loose, then the door came off. We also found out in the process that the doorknob previous owner had smacked the mirror so hard that it bent the rubber metal window housing unit, and any mirror that I have on there will not be straight. Its so frustrating! So I need to buy a new housing since there's really no way we can put it back into the correct shape. I have less wind noise now with the new mirror, but I still have noise. I also discovered I have a slight leak on the corner of the windshield. I'm hoping to take it by a glass place one of these days and have them reseal it. You know, it always seems to be something! :-(
tresola
